  3. A printf wrapper
  • Views 15444
A printf wrapper
mb47
mb47 over 18 years ago
Dear skilled cadencers,
I'd like to write a wrapper for the printf() function. The problem is
that I do not know how to have a variable number of arguments. I tried
with @rest:
procedure( myPrint(port str @rest args)
    fprintf(port str args)
    newline(port)
however this won't work because args is a list and fprintf (or printf)
complains about that.
How can I achieve this task?
mb
  • dmay
    dmay over 18 years ago
    Take a look in the Skill Language Reference Index for "Comma-At" documentation. With this syntax you can get your function working:
        apply('fprintf `(,port ,str ,@args) )
        newline(port)
    port = outfile("/tmp/test.txt")
    myPrint(port "Hello %s %d" "derek" 1)
    myPrint(port "Hello %s %d" "joe" 2)
    myPrint(port "Hello %s %d" "zeke" 3)
    close(port)
    The documentation states:
    In absence of commas and the comma-at (,@) construction, backquote functions in exactly the same way as single quote. However, if a comma appears inside a backquoted form, the expression that immediately follows the comma is evaluated, and the result of evaluation replaces the original form.
    The comma-at construction causes evaluation just as the comma does, but the results of evaluation must be a list, and the elements of the list, rather than the list itself, replace the original form.
     -Derek
