  3. Boundary’s coordinates
  • Subscribers 152
  • Views 5885
sooky
sooky over 18 years ago
Hi friends:
I want to know is it possible to get the Boundary’s coordinates of a cell.
How to get this.
  • Bernd
    Bernd over 18 years ago
     Get the cell view Id
     either for an cell  view open in a window with
    d_cvId = geGetEditCellView( )
     or with
    d_cvId = dbOpenCellViewByType( t_libName t_cellName t_viewName )
    and then
     dbComputeBBoxNoNLP(  d_cvId )
     => l_bBox
    returns the list with the bounding box coordinates.
    - Bernd
  • sooky
    Thanks Bernd.
  • ahamlett
    ahamlett over 18 years ago
     or with
    and then
     => l_bBox
    - Bernd
    Also, d_cvId->bBox will return that cell's bounding box.
  • blankman
    blankman over 12 years ago
    All,
    I'm looking to get the outline of all instances and shapes in a cellview, akin to a shrink wrapped boundary, to create a metal fill keepout halo around the block.
    The only way I can see to do this at the moment is flatten everything, convert all shapes to a common layer, and merge.
    Is there another means of doing this, ie a command that would give the coordinates of the outline?
    First of all, the forum guidelines ask you not to post on the end of old threads. This one is 5 and a half years old!
    There was some discussion in this thread on finding the convex hull of a set of shapes - so a similar problem.
  • blankman
    Thanks Andrew,
    I was not aware of this, duly noted.
    Brian.
