  3. How to find if a coordinate is on a net
  • Subscribers 152
  • Views 16252
bimukt
bimukt over 17 years ago
I neeed to find if a coordinate is on a metal1 net.
The net is a randomly drawn path on a layout.Is there any skill function available
  • istjohn
    istjohn over 17 years ago
     You could always turn the point into a small bbox and use dbGetTrueOverlaps to see what nets are under it. Or, if you want the most accurate method, you can do something like this:
    cv=geGetEditCellView()
    foreach(net cv~>nets
    foreach(fig net~>figs
    if( absIsPointInsideFig(fig pt ) then
    foundNet = net~>name
    );if
    );foreach
    );foreach
    foundNet ;name of net under point
  • dmay
    dmay over 17 years ago
    Another simple approach is to use gePointQuery. This is similar to geSingleSelectPt except that it doesn't do the selection. The routine takes three arguments: window id, coordinate and filter function.
    result=gePointQuery(hiGetCurrentWindow() 10:20 "myFilter")
    procedure(myFilter(fig)
        if(fig~>layerName=="metal1" && fig~>objType=="path"
            t
            nil
    Derek
  • bimukt
    HI John,
    I need to find if the coordinate is on the net.Actually my script will move all pins to the routing grid.I have found the coordinate of the nearest routing grid and move the pin there.
    I need to check that the new position of the pin is on the same net otherwise the pin will lose the connectivity with parent net.
    When I found the net from the pin and use the function this returned nil for a coordinate on the net.I gave the dbId of the net for this.
    also to give the id of a figure ...I probed all figs by net~>figs.....there was no fig found..
    In this case how will I check the coordinate is on the net.
