  3. Skill code for finding coordinates of selected instances...
  • Replies 18
  • Subscribers 154
  • Views 35146
Skill code for finding coordinates of selected instances in the layout
Vignesh054
Vignesh054 over 17 years ago
 I need a skill script to find the co-ordinates of all selected instances in the layout?
Can anyone help me on this?
Vignesh T K
  • dmay
    dmay over 17 years ago +2
    Coordinates come in a variety of ways, depending on the objects you select. All instances have xy and bBox attributes. The xy will be the origin of the instance. The bBox will be the bounding box of the…
  • dmay
    coordList = nil
    foreach(item geGetSelSet()
        printf("Selected item coordinate: %L\n" item~>xy)
        coordList = cons(item~>xy coordList)
  • Vignesh054
     Thank you for the reply.
    I need lower left(llx,lly) and upper right (urx,ury) coordantes. And also is it possible to print the instance name with the coordintes?
    Can you help me on this?
    Vignesh T K
  • dmay
    Coordinates come in a variety of ways, depending on the objects you select. All instances have xy and bBox attributes. The xy will be the origin of the instance. The bBox will be the bounding box of the instance. All shapes have a bBox, but polygons and paths also have a set of points.
    A bBox comes as a list of two coordinates: bBox = list(list(x1 y1) list(x2 y2))
    To get the lower left:  ll = car(bBox)  or  ll = lowerLeft(bBox)
    To get the upper right:  ur = cadr(bBox)  or  ur = upperRight(bBox)
        ll = lowerLeft(item~>bBox)
        ur = upperRight(item~>bBox)
        case(item~>objType
            ("inst"  printf("Instance %s of cell %s at  xy = %L, ll = %L, ur = %L\n" item~>name item~>cellName item~>xy ll ur))
            ("rect"  printf("Rectangle with ll = %L and ur = %L\n" ll ur))
            ("polygon" printf("Polygon with ll of extents at %L and ur of extents at %L and points %L\n" ll ur item~>points))
            ("path" printf("Path with ll of extents at %L and ur of extents at %L and points %L\n" ll ur item~>points))
    This is basic Skill. You should take a look at the Skill user's guide. You should also explore available attributes on an object to see what you can do. Here is a simple thing to do:
    Select one item in layout. Then in your CIW do this:  x = css()
    This will assign the "car of the selected set" or car(geGetSelSet()) to the variable x.
    Then do this in the CIW: x~>?
    This will show you the attribute names available on the selected item.
    Then do this in the CIW: x~>??
    This will show you the attribute names and values on the selected item.
    Try this with instances, rectangles, paths, polygons, or any other objects you may be using.
    You can also traverse these items as deep as you want. For example, if you select an instance in the layout, you can do the following:
    inst = css()
    instName = inst~>name
    instMaster = inst~>master
    termsInInst = instMaster~>terminals
    This could also be done like this:
    css()~>master~>terminals
    css()~>master~>terminals~>name
    Time to dig out the manual.
    -Derek
    • Vote Up +2 Vote Down
  • Vignesh054
    Thank you very much for the reply.
    It is working fine..Since i am new to the skill i couldn't go in deep.
    Can you point me to a user guide for learning skill
    Vignesh T K
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
     Hi Vignesh
    The best way to learn SKILL is to look at other SKILL programs. There are lots of examples here on this site and under Source Link. In addition, the user manual  SKILL Language User Guide will give you lots of the background to the language. I always learn best when I have a specific problem to solve.
    Things to learn:
    Lists: Pretty much the standard method for holding lots of data.
    db... commands: Database access
     foreach: A looping structure for processing lists
    if, when, unless, case, cond:  conditional statements.
     Good luck and stay with this forum as there are lots of very good SKILL users here.
     Ted
  • bharath2k4er
    bharath2k4er over 17 years ago
     can you add a line to above script,
    How to select all the instances?and get their coordinates and instance names?
    second part is answered..need help in first part.
    Bharath.
  • Austin CAD Guy
     I usually parse instHeaders instead of instances if I am looking for placements of specific masters:
     foreach( ih deGetCellView()~>instHeaders
       when( { test for matching master name is true }
            foreach( inst ih~>instances
                geSelectObject( inst )
            ) ; foreach
         ) ; when
    ) ; foreach
    To just get all the instances:
    foreach( inst deGetCellView()~>instances
        geSelectObject( inst)
    ) ; foreach
    Ted
  • dmay
    I highly recommend looking into the documentation. Cadence has some great docs and online help. Try running cdsFinder from your shell window (or startFinder from your CIW window). In the search field, search for select. Look at the commands that start with ge for graphical editor. Other commands you find useful will start with hi, le, db, sch. It is usually easy to find what you need. Follow the tips listed earlier for looking at the attributes of objects. Use the Cadence docs for more details on commands. Then, answering your question is easy.
    cv = geGetEditCellView()
    foreach(inst cv~>instances
        geSelectFig(inst)
        printf("Inst name: %s  xy: %L  bBox: %L  cellName %s\n" inst~>name inst~>xy inst~>bBox inst~>cellName)
    -Derek
  • 0007
    0007 over 16 years ago
    You select the instances and use the
    db command: dbGet selected.pt
    Anil
    Hi Anil,
    That is a Tcl command for Encounter. This forum is for Custom IC SKILL (and this post was 18 months old anyway, and answered already).
