  3. skill precision for floating points
  • Views 17398
Galaind
Galaind over 17 years ago
I was wondering about how skill store floating points number,
Can any one provide more info
  • oldmouldy
    oldmouldy over 17 years ago
    Refer to page 133 of the Skill Language User Guide, "SKILL stores all floating point numbers in double precision"
  • Galaind
    Thanks alot for your help,
    But is this mean that skill repesents number as IEEE compliant double precision
    I'm facing some problems in calculating layout points some points after calculation is a single grid off the expceted place.
  • Tongju
    Tongju over 17 years ago
    When you got your result back onto grid, which function did you use?  A while ago, I used function "int" by mistake, it cut my result by one grid down from time to time.  Then, I switched to anothre function "round" or some formula like int(result/grid + 0.0000001)*grid to work-around it, then, everything looks ok to me.
     Tongju
  • Galaind
    thanks for your help, I tried round and it passed the correct results to me.
