  3. Problem with running a c program via Cadence
  • Views 15592
useratcad
useratcad over 17 years ago
I'm trying to run a program located at ~/src/prog/myprog written in Cpp.
But when I want to start it with
ipcBeginProcess("~/src/prog/myprog") it won't work.
Cadence says:
sh: ~/src/prog/myprog: not found
What is the problem here?
A complete path will work, but I need the short one, like above.
And another question: What is the best way to run commands? Via ipcBeginProcess, sh or internal functions like (CreateDir. DeleteDir, ...)
ipcBeginProcess("mkdir -p test")
CreateDir ("test")
sh("mkdir -p test")
Thanks Tim
  • skillUser
    skillUser over 17 years ago
     Hi Tim,
    You can use "simplifyFilename()" to expand a file name to a fully qualified path, for example:
    ipcBeginProcess(simplifyFilename("~/src/prog/myprog"))
    For your question about which is best, it really depends on what you need to do; if bi-directional communication is required between DFII and the external program, then use the ipc* functions, but if you just need to fire off an external command and don't need any further interaction with it, use one of the csh(), sh(), shell() or system() commands.
    Hope this answers your questions!
    Lawrence.
  • useratcad
    great! Thanks for the reply. That helped a lot!
