  3. Get current script directory
  • Views 20014
useratcad
useratcad over 17 years ago
I need to find the current dir of the loaded skill file to automatically load the other files in the folder.
I found that  "get_filename(piport)" will return the skript name, but not the dir.
How could I do that?
Thanks Tim
  • skillUser
    skillUser over 17 years ago
    Hi Tim,
    Using your idea of get_filename(piport), I have expanded it a little to obtain the root of the directory name.
    This seems a little clunky, and I have only tested it under a couple of conditions, but it seemed to work:
    when(file = get_filename(piport)
     ;; expand the file using the SKILL path
     matches = foreach(mapcar path getSkillPath()
      when(isFile(strcat(path "/" file ))
       simplifyFilename(strcat(path "/" file ))
     full = car(setof(item matches item))
     when(full
      ;; convert the path into a list of strings
      ;; and remove the filename from the list
      path = remd(file parseString(full "/"))
      ;; convert the list of strings back into a
      ;; single string, prepending with "/" for a
      ;; fully qualified path
      root = strcat("/" buildString(path "/"))
      ;; print and return the file directory root
      printf("root dirname: %s\n" root)
      root
  • useratcad
    Awesome. I modified it a little and it works perfect. Thanks for your help!
