  3. rename cells automatically with "Update Instance" selec...
  • Replies 7
  • Subscribers 150
  • Views 9412
rename cells automatically with "Update Instance" selected
marcop
marcop over 17 years ago
 Hi all,
I need to rename a lot of cells and change also the references from old cell to new ones.
From Library Manager it is present "Rename Cell" with Update Instance that is the right function, but I did't find skill code to do the operation automatically.
Marco
  • skillUser
    skillUser over 17 years ago
    Hi Marco,
    You can use the ccp* functions combined with the gdm* functions to achieve this.  For example there is a ccpCopy function that can perform a copy followed by an update operation. Here is a snippet taken from my CCShierCopyCell.il that can be found on SourceLink:
    ccpCopy(
          specList        ;; source spec list
          destSpecList        ;; destination spec list
          nil            ;; overwrite?
          'CCP_NO_EXPAND    ;; expandflag
          nil            ;; copyViewType list
          nil            ;; copyViewName list
          ""            ;; viewName regular expression
          "CDBA"        ;; name space referring to previous 2 arguments
          'CCP_UPDATE_DESTLIB_ONLY    ;; whatToUpdate
     Get the code here or here
    Also, check the documentation for the ccpCopy(), ccpExpandDesign(), gdmCreateSpec(), gdmCreateSpecList(), gdmAddSpecToSpecList(), gdmResetSpecList() and gdmInspectSpec() SKILL functions.
     I hope this helps you.
    Lawrence.
  • marcop
     Hi Lawrence,
    thank you for you help
  • LeO99
    LeO99 over 14 years ago
    where to find documentation on ccpCopy() function.
    How about using the search capability in the documentation? You can get to the documentation either using the Help menus in the tools (surprise, surprise), or by using cdnshelp in IC61 or cdsdoc in IC5141. Or you can search on Cadence Online Support.
    Or if that's too difficult,  it's in <ICinstDir>/doc/caiuser/caiuser.pdf (The Cadence Application Infrastructure Guide).
  • LeO99
     Well Andrew that helped. But while copying and updating cells in the destination library only a few of the cells are updated and not all of them. Can you think of something why this is happening.
    Not based on the information you've provided.
  • LeO99
     The purpose of the script is to rename the cells in the source library and copy them to the destination library. This script creates a GUI wherein you have to give the name of the source library, destination library, prefix and suffix. Suppose you have a cell named XYZ in source library than it will be copied as "prefix"XYZ"suffix" to the destination library. But not all the cells are updated in the desitnation library. For more clarity I am attaching the SKILL code with this reply.
    ccpCopy.il
