  3. truncating a File
  • Subscribers 152
  • Views 16308
truncating a File
useratcad
useratcad over 17 years ago
 is there an easy way to truncate the beginning or the end of a file?
I tought I can find a special position in file and then truncate the rest of it resp. cut everything above.
Thanks Tim
  • Bernd
    Bernd over 17 years ago
    I'm not sure if can modify a file on the fly in SKILL,
    at least I never have done this.
    You can open a file read it's contents and copy the contents you
    want to a new file.
    Have a look at the
     - SKILL Language User Guide
      o I/O and File Handling
        * Working with File Offsets (fileTell, fileSeek)
    Bernd
  • useratcad
    Thanks for the hint.
    I was poking around with fileTell &fileSeek, but it seemed too complicated to open a file then copy all the data until the 5th last line was reached. I can't even figure out, howto check if EOF is rechead within a while-loop or so.
    Maybe there is a better solution for my problem:
    I need to read and write some values into a config file like the windows ini-files:
    startdir=/etc/bin/
    mytext="hello world"
    oneNum=5
    Thanks Tim
  • Bernd
    Something like that?
    procedure( BFreadConfig( t_inFile "t" )
        let( ( l_keyValueList p_inPort t_key t_line t_value )
    p_inPort = infile( t_inFile )
    when( p_inPort
        while( gets( t_line p_inPort )
            when( t_line && t_line != "" && t_line != "\n"
            l_keyValueList = parseString( t_line "=" )
            t_key = car( l_keyValueList )
            t_value = cadr( l_keyValueList )
            printf( "Key: %s, Value: %s\n" t_key t_value )
            ) ;; close when
        ) ;; close while
    ) ;; close when
    close( p_inPort )
    ) ;; close let
    ) ;; cloes procedure
    procedure( BFmodifyConfig( t_outFile t_key t_value "ttt" )
        let( ( l_keyValueList p_inPort t_line p_outPort t_tmpFile )
    t_tmpFile = strcat( t_outFile ".tmp" )
    system( strcat( "cp " t_outFile " " t_tmpFile ) )
    p_inPort = infile( t_tmpFile )
    p_outPort = outfile( t_outFile )
    when( p_inPort
            if( t_line && t_line != "" && t_line != "\n" then
            if( t_key == car( l_keyValueList ) then
                fprintf( p_outPort "%s=%s\n" t_key t_value )
            else
                   fprintf( p_outPort t_line )
            ) ;; close if
        else
            ) ;; close if
        ) ;; close while
    ) ;; close when
    close( p_inPort )
    close( p_outPort )
    system( strcat( "rm -f " t_tmpFile ) )
    ) ;; close let
  • useratcad
    looks great!
     Thanks a lot, that helps definitly
