  3. dbCreateInst with parameter property
  • Views 18031
ebecheto
ebecheto over 17 years ago
Hi all,
I want to create layout instances with the function 'dbCreateInst' of an instance that has some parameters, let say "width" and "length"
However with the following code-line, it is not possible to specify the parameters.
(dbCreateInst (getEditRep) (dbOpenCellViewByType library "myCell" "layout") nil (list xpoint ypoint) "R0")
 When using the graphical interface : 'leHiCreateInst' we are able to change the default values of the parameters and then we can see them selecting the instance and typing : css()~>prop~>??
But when I use dbCreateInst to create the instance, there is : 'nil' in the 'prop' field ...
Does anyone know how to insert a cell with parameter, or how to change the parameters after insertion ?
Thanks for any piece of advice.
  • Bernd
    Bernd over 17 years ago
    dbCreateParamInst(
    d_cellView
    d_master
    t_name
    l_point
    l_orient
    [ x_numInst
    [ l_params ] ]
    Bernd
  • ebecheto
    Your fully right,
    How come I haven't found that before ?! Thanks for your help.
  • bharath2k4er
    bharath2k4er over 17 years ago
     Is it possible to add an extra parameter for the exisiting instance.
    say, i want to lock(shouldn't be able to perform move or stretch commands) the position..??
