  3. "Browse for folder"- Dialog
  • Views 2260
useratcad
useratcad over 17 years ago
I'm looking for a way to open a DialogBox where the user can select a directory. Is there a function for that or is there a way to print out a FolderTree in a Box?
Thanks in advance
Tim
  • skillUser
    skillUser over 17 years ago
    Hi Tim,
     I think that you want the ddsFileBrowseCB() function, it is hidden well in the documentation, but here is some brief information (from cdsFinder):
    ddsFileBrowseCB( r_form s_targetName [ t_filter ] [ s_mode ] [ t_caption ] )
         => t | nil
    Creates a file browser dialog for specifying file names through browsing.
    There is an example in SourceLink Solution 11457794
    Lawrence.
  • useratcad
    Great! You guys rock!
  • useratcad
    One more thing:
    somehow if I press in that Dialog the [OK]-Button it is not closing there is only a message "hiFormDone(_ddsFB_CelldocuInputForm)". I have to press [Cancel] in order to exit. Is there a workaround for that?
    2nd) And I was wondering if there is a function or way, that if I resize the for, that all the elements will resize themselves, too.
    So if I resize the window from 500 to a width of 400 the StringField should be 380 instead of 480 as well.
