  3. Editing VerilogA parameters using SKILL script
  • Views 15245
Shamnur
Shamnur over 17 years ago
Hi All,
I am working on script to modify the CDF parameter( the VerilogA design parameters) of a cell.
E.g: A veriloga parameter (say "length" in "myCell") need to be modified using SKILL routine.
cellObj = ddGetObj( "myLib" "myCell" nil nil nil "a")
bcCdf = cdfGetBaseCellCDF( cellObj)
if( bcCdf->parameters->name == "length")
then
    lengthParam  = nth( i bcCdf->paramters)
    lengthParam->defValue = 44
);if
 >>>> *WARNING* Can't modify attributes of effective CDF parameters.
However, this warning inhibits me to modify any parameters similarly.
Is there a way, I can bypass this and edit the parameters ?
Please let me know if the community has a solution for this.
Shamnur
  • skillUser
    skillUser over 17 years ago
     HI Shamnur,
    If this code above is your actual code that has been copied and pasted here, then there is a typo that may be causing problems:
    perhaps this should be:
    lengthParam  = nth( i bcCdf~>parameters)
    I'm sure that there is a cleaner way than using "nth" but I can't see the surrounding context, so I don't know exactly what the rest of your code looks like. You might consider the cdfFindParamByName() SKILL function:
    cdfFindParamByName( g_cdfDataId t_name )
         => g_paramId / nil
    Use the "squiggly arrow" (tilde followed by greater-than) when working with cdf or db objects.
    Lawrence
  • Shamnur
    Hi Lawrence,
    Thanks for the close observation. The typo is only in composing this post however it isn't there in my actual code.
    Well, I realized a solution for my problem which I would like to share. However this has pushed me into another problem which happens to be the continued discussion.
    Solution:
    We can edit the parameter(say lengthParam) values in two ways.
    1) cdfgData->lengthParam->defvalue =33
    2) cellObj = ddGetObj( "myLib" "myCell" nil nil nil "a")
        lengthParam  = nth( i bcCdf->parameters) ; Assuming ith value is lengthParam
       lengthParam->defValue = 33
    The first one would issue the mentioned Warning message which I had interpreted wrongly before and the second one wouldn't issue the warning message. So, going by (2) method solved my problem.
    New Problem:
    a) When I attach a callback message to the same parameter which happens to be a dialogBox to lengthParam->callback, it fails !!
    e.g: lengthParam->callback = "hiDisplayAppDBox(?name 'f ?dboxBanner \"Warning\" ?dboxText \"The defValue is being assigned back\" ?dialogType hicWarningDialog ?dialogStyle 'modal ?buttonLayout 'OKCancel ) "
    It is leading to segmentation faults !!
    b) If I were to attach a  callback which is a simple print statement etc, the results are fine.
    e.g: lengthParam->callback = "printf(\" I am assigning the value back to default\")"
    Ganesh
