  3. Skill automation of analog environment and analysis
  • Subscribers 152
  • Views 15815
jmoore
jmoore over 17 years ago
I am trying to write a skill script which setts up analog environment, runs several simulations and then does some analysis of the data. I have the sett up and run portion working, but can not figure out a way of weighting for the simulation to finish to retrieve the data with out blocking and sucking cpu resources with a wile loop. What is needed is some form of call back or delayed polling of ( results() == '(variables) ) any advice would be appreciated.
start simulation:
sevNetlistAndRun('sevSession1)
current method of testing for simulation to complete non functional:
while( results() == '(variables) nil ) ;
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
     You could try hiRegTimer which will perform a wait and then wake up and execute a callback:
    hiRegTimer( "results()" 100 )
    Runs results() every 10 seconds. All your processing should be done within the callback.
     Ted
  • Ramesh
    Ramesh over 17 years ago
    Hi , I guess ipcBeginProcess will work for your requirement.
    If you can give a sample exmaple I can explain indetail.
