  3. Status of Full/Partial select toggle?
  • Views 2378
J Wilwert
J Wilwert over 17 years ago
I want to determine the status of the Full/Partial select toggle.
This code:
printf("F/P setting: %L" envGetVal( "layout" "partialSelect") )
always prints a nil.
Am I using the correct function?  Ideas anyone?
THANKS,
John Wilwert
  • skillUser
    skillUser over 17 years ago
     Hi John,
    The envGetVal() method gets the default setting for the session, but it is also a per-window setting.
    You can get the current window partial select setting using something like the following:
      hiGetCurrentWindow()->partialSelect
     You can see other per-window settings (such as x and y snap spacing) using hiGetCurrentWindow()->??
    Hope this helps.
    Best regards,
    Lawrence.
  • J Wilwert
    Hi Lawrence,
    Thanks - I made the adjustment in my code and all is good!!
    John Wilwert
