  3. Number of icfb executables running
  • Replies 8
  • Subscribers 153
  • Views 18219
mims
mims over 17 years ago
When I have 10 Cadence executables running I am not able to open an 11th one. Is this some operating system constraint, a Cadence constraint, or some local issue of mine?
Thanks!
  • skillUser
    skillUser over 17 years ago
    My guess would be that the log file numbering is sequential (the default) and that it is limited to 10?  You could try starting icfb with the -log switch to specify a different file name/location for the CDS.log file, or use the following:
    setenv  CDS_LOG_VERSION  pid
    I hope that this helps you.
    Lawrence.
  • aplumb
    aplumb over 17 years ago
     How much physical and swap memory do you have on that machine?  Just launching (IC6.1 virtuoso in my case) takes up ~100MB.  Start opening any kind of design data in each of those session and you're going to get to ~200MB per session pretty quickly.  If you don't have enough swap space you're going to run out pretty quickly.
  • aplumb
     Cool!  Didn't know about that 'CDS_LOG_VERSION' variable.
    Learn something new every day. :-)
  • mims
    Thank you Lawrence,
    The CDS_LOG_VERSION =pid worked perfectly.
    mims
  • ahamlett
    ahamlett over 17 years ago
    The CDS_LOG_PATH environment variable holds a list of the directories in which the CDS.log file is saved into the first writable directory.
    If CDS_LOG_VERSION is set to "sequential" how can I find the file name of the current CDS.log file?
    Incrementing a counter and checking if each log file exists won't work because that just gives the newest CDS.log unless some were deleted, while I need the current CDS.log file.
    Andrew Beckett over 17 years ago
    Alan,
    hiGetLogFileName()
    will do what you want.
  • rajeshcad
    rajeshcad over 17 years ago
    More the number of icfb more the amount of VM used. File->Close data does not release the memory to system pool. If one of the session opened something really big then untill the session is closed your memory is blocked with that session. Be very cautious with multiple sessions.
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
     There also may be an operating system limit on how manyopen files you can have. This will often be the limiting factor and may not generate any error message. Use the ulimit -a command to see the number of files you are allowed to have open at one time. Remeber that there may be even more files open than just the log file and the current cellView.
    Ted
