  3. ddDeleteObj doesn't work in nograph mode
  • Views 3644
SkillStudent
SkillStudent over 17 years ago
I am trying to delete cells by feeding the SKILL code to icfb in nograph mode. The following code works through the GUI but not in nograph mode:
when(ddGetObj(lib cell)
    ddDeleteObj(ddGetObj(lib cell))
Any solutions?
  • fxffxf
    fxffxf over 17 years ago
     wrong forum
  • skillUser
    skillUser over 17 years ago
    This is the appropriate forum for this question.
    It worked for me when I tried it (using IC5141USR5 and also 5.10.41.500.6.129)
    > cell = ddGetObj("deleteMe" "removeMe")
    dd:0xbfbf684
    > ddDeleteObj(cell)
    t
    In what way does it not work for you?  Which version are you using?
    Lawrence.
  • SkillStudent
     Hi lawrence,
    I am using IC6.1.3, and I run 'virtuoso -nograph -replay file.il'. I just realized that I get the this message: *WARNING* ddDeleteObj: ddCellType 'removeMe' owns files that are in use by other users, because I am running another virtuoso at the same time. Is there a way to force the deletion?
  • aplumb
    aplumb over 17 years ago
     It could just be that an intermediate variable isn't being used:
    ddDeleteObj(ddGetObj("deleteMe" "removeMe"))
     ...may work from the interactive parser but won't necessarily work in a script.  I've seen similar behaviour in the other code I've written so I'm always in the habit of breaking up the operation as Lawrence showed.
    Aside: You may need to follow the 'ddDeleteObj(cell)' with a 'ddReleaseObj(cell)'.  In general, matching 'myVar=ddGetObj(...)' with 'ddReleaseObj(myVar)' makes life a lot easier when you start doing more complex creation/editing of database-linked objects like 'verilog.v' or 'expand.cfg' files.
  • skillUser
     If the ddReleaseObj() suggested by Andrew did not work, it may be that the file (or files) is locked.You might use ddLockFree() and other ddLock* functions to free the lock and then this should allow you to delete the cells.
    Lawrence.
