  3. skill code for output console window
  • Subscribers 152
  • Views 17854
ramya
ramya over 17 years ago
I am new to this forum.I found this forum very informative. Can someone help me with below code?
How to develop a output console using skill coding which displays the action done in the layout(like displaying the details when a command is executed)
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
     It requires you to open an output file for writing, viewing the file with update turned on, writing to the file and draining the buffer to display it:
     myTempFile = makeTempFileName( "testFile" )
    ;; Open the file in write mode (clean file) as opposed to append
    myFileId = outfile( myTempFile "w" ) || error( "Could not open %s\n" myTempFile )
    view( myTempFile nil "Title of view window" t ) ; the last argument makes the window updatable
    fprintf( myFileId "This is a test of the view file system\n" )
    drain( myFileId )
    ;; Be sure to close the port when finished
    close( myFileId )
    Hope that helps. You can control the size of the window and where it ends up with the view command.
      Ted
  • ramya
    Thanks for your reply.
    But i would like to have is this new window that is created should display description of the commands that are executed in the layout window.
    Like when saving a cell view is done, the message window has to display the message like "cell view is saved sucessfully" something like that.
    please give me some ideas for this.
  • Austin CAD Guy
     There are some actions which you can do this for using triggers and dialog boxes but not all actions have triggers which can be registered. Something like a save has three possible triggers dbRegSaveTrigger - Pre save, dbRegPostSaveTrigger - After save and dbRegPurgeTrigger. Each command registers a command which is executed at the proper time. You can find all the triggers using cdsFinder - type cdsFinder in the shell and then enter trigger in the "Find what:" box. cdnsHelp or cdsdoc (release dependent names) have more explanation about the usage of the triggers.
    You may want to display your message using a dialog box. Use the hiDisplayUserDBox command to create a dialog box. A progress box can be done with hiDisplayProgressBox. Both of these are described in the documentation but this gives you a place to start looking.
     Ted
