  3. Step wise execution of skill scripting
  • Subscribers 150
  • Views 17909
bharath2k4er
bharath2k4er over 17 years ago
      Can anyone suggest me if step wise execution of skill coding is possible.. say in case of c programming after compiling the program with 0 errors, we can see the step by step execution of the program by pressing F7 key.... is the same way possible in skill..?
 what are types available to compile a skill program..?
Bharath.
  • dmay
    dmay over 17 years ago
    If you own the skillDev (Skill Development) license, then there is a Skill debugger that you can use to step through your code. Go to the Tools menu in the CIW to find the Skill Development option.
    CIW->Tools->Skill Development
    Then click on the Skill Debugger button. Load your code into your CIW after opening the debugger. You can put statements like break() into your code to set break points, or you can use the debugger interface to define what functions to use as break points. All the code stepping will be displayed in the CIW. I recommend you look at the documentation for how to use the debugger. Most of the buttons on the form have corresponding Skill commands that you can put on bindkeys if you wish (Set F7 to step, for example).
    You can use the sstatus command to help you debug problems in your Skill code as well. Two settings I find useful are:
    ;The following gives you a stack trace up to 10 levels deep if your skill code fails
    sstatus(stacktrace 10)
    ;The following will print the values of all the variables in the procedures in your stack trace at the time of failure
    sstatus(stacktraceDump t)
    -Derek
  • bharath2k4er
     Thanks for your support Derek..!!!
    Hope i get the usage doumentation of 'skill debugger' in virtuoso user guide.
    Bharath.
