  3. Conversion of a text to a logo
  • Subscribers 152
  • Views 17638
Vasili
Vasili over 17 years ago
 I already was told that there is no simple skill code that
would allow to convert an arbitrary text, say, presented as a label
into a shapes (polygons). However, this is rather strange for me.
This is why I would like to ask this question again. It is easy to see
that lables are built from lines. Maybe it is possible "to interseptlabels
and convert them to, say, lines or paths?
 Vasili
  • skillUser
    skillUser over 17 years ago
     Hi Vasili,
    This is not strictly true; there is a "PG Text" capability built right into the tool, as a feature of Turbo Toolbox (it is available in IC5141 and IC61x versions) - look for that as a search string in SourceLink and you should find some good information.
    In addition to this, there are sure to be several versions of AE-ware and customer code that has been written for this purpose, but I think your best bet is probably to use Turbo Toolbox.
     Hope this helps you!
    Lawrence.
  • Bernd
    Bernd over 17 years ago
    Logos and text in Cadence Virtuoso have been discussed over years,
    additional to Lawrence suggestion here are some more.
    Find the most appropriate for you.
    - There is an old discussion on this in comp.cad.cadence:
    http://groups.google.com/group/comp.cad.cadence/browse_thread/thread/463bef496a1ef938/325dc091b0990435
    - p2m Gimp plugin
    http://www.cadence.ncsu.edu/p2m/
    http://www.eda.ncsu.edu/wiki/Tutorial:P2m
    I found the plugin here
    http://schumaml.gmxhome.de/downloads/gimp/
    - SourceLink solution for 6.1.x
    http://sourcelink.cadence.com/docs/db/kdb/2009/Jan/11528792.html
    - Andrew Beckett has a SKILL script 'abXpmToLayout.ils', he is member in this forum as well
    http://www.cadence.com/community/members/Andrew%20Beckett.aspx
    and if you send him a pm he surly will provide this to you.
    Bernd
