  3. Problem in setting outlineStipple as fill style(virtuoso...
  • Views 827
Problem in setting outlineStipple as fill style(virtuoso 51)
jerg
jerg over 17 years ago
I use "geAddHilightPolygon" to draw polygons.
My color/fill setting is as follows:
DisplayName  PacketName       Stipple    LineStyle      Fill        Outline     FillStyle
display                y7               blank      thickLine      yellow       yellow   outlineStipple
If preview in Display Resorece Editor, the setting looks like a yellow/BLANK pattern.
However, when I use the packet to highlight a rectangle and expect it to be a blank rectangle,
it shows a yellow/SOLID one!
The trick is that, if I try to set the Stipple as slash(works well), and then set it back to blank,
I'll finally get a yellow/BLANK rectangle.
Any comment on this?
Thanks!
BTW, virtuoso 61 has no this problem.
