  3. What's the differene btw dbCopyProp and cdfCopyCDF
  • Views 1890
SkillStudent
SkillStudent over 17 years ago
 which one should be use to copy cdf data from one cell to another
  • aplumb
    aplumb over 17 years ago
    Are you trying to copy the CDF itself (as edited with CIW - Tools - CDF - Edit) or a given cellview's properties (as edited in a Layout/Schematic/Symbol via Edit - Properties - Cellview)? CDF exists at the Library or cell level - use cdfCopyCDF to copy these. Database properties exist at the view level; they override whatever defaults may be established by the CDF - use dbCopyProp to copy these. The dbCopyProp command isn't restricted to operating on a cellview either (i.e. the object pointed at by geGetWindowCellView() or dbOpenCellViewByType() commands). It could just as easily be an instance, figure, net, etc. contained within a cellview. Hope this helps! Andrew.
  • SkillStudent
     Andrew, your explanation was very helpful, Thanks.
  • aplumb
    No problem! Sorry about the formatting; the forum interface doesn't play nicely with Safari. Andrew.
