  3. *Error* lineread/read: syntax error encountered in inpu...
  • Views 8414
*Error* lineread/read: syntax error encountered in input
SUBBHAREDDY
SUBBHAREDDY over 17 years ago
Hi Guys
I used to get the below error after running set of skcomref commands in CIW window.
Pls help out to resolve the issue.
The sequence of skill code i run in CIW window :
cv=dbOpenCellView("IOLIB_65_M10_CUP_TC_N" "ANA_TC_ISO" "cmos_sch" nil "a")
db : 8967243
wireid=car(schCreateWire( cv "draw" "full" list(0:0 1:0) 0.0625 0.0625 0.0 ))
db : 7857643
schCreateNetExpression( cv [@REDDY:%:REDDY!] wireid (1:0) "REDDY1" "lowerLeft" "R0" "fixed" 0.0625 )
SYNTAX ERROR found at line 7 column 28 of file *ciwInPort*
Thanks and regards
Subbhareddy
  • skillUser
    skillUser over 17 years ago
     Hi Subbhareddy,
    I think that the problem is that the net expression is not enclosed in double quotes - the documentation for schCreateNetExpression shows that the nexExpression argument is a text string:
    d_cvId
    t_netExpr
    d_glueId
    l_point
    t_justify
    t_orient
    t_fontStyle
    n_fontHeight
    Add the double quotes around [@REDDY:%:REDDY!] and it should be syntactically correct.
    Lawrence.
  • SUBBHAREDDY
    Yes,you are correct,documentation shows like that only,i tried in that way also.
    I used to get different error as of below :
    schCreateNetExpression(cv "[@REDDY:%:REDDY!]" wireid (1:0) "REDDY" "lowerLeft" "R0" "fixed" 0.0625 )
    *Error* schCreateNetExpression: too many arguments (8 expected, 9 given) - (db:79867948 "[@REDDY:%:REDDY!]" db:85983388 (1 0) "REDDY1" ... )
    Thanks and regards
    Subbhareddy
  • SUBBHAREDDY
    Hi Guys
    The issue was dbOpenCellView is replaced by dbOpenCellViewByType function.
    Thanks and regards
    Subbhareddy
