  3. How to find out wire is present in the path in schematic...
  • Views 15747
How to find out wire is present in the path in schematic window
SUBBHAREDDY
SUBBHAREDDY over 17 years ago
Hi Guys
I am creating a wire with wire net expression in virtuoso schematic window.
Before creating a wire i want to check whether ,the new wire creating by me is merging with the old wire already present,
or touching the wire etc? Pls help me out how to find out ?
 For creating of wire i am using the below command and it works fine :
 wireid=car(schCreateWire( cv "draw" "full" list(0:0 10:0) 0.0625 0.0625 0.0 ))
 If u know ,pls let me know .
Thanks and regards
Subbhareddy
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
     The command dbGetTrueOverlaps can be used to detect existing data at a point or within a bounding box.The bounding box could be just a repeated point (a box with 0 area)
    connWire = dbGetTrueOverlaps( cv list( 1:0 1:0 ) list("wire" "drawing") 0:0 )
    That searches at 1:0 for anything in the current cellView (start/stop level 0:0) for any shape on wire/drawing. Do this before you create the new wire.
     Ted
  • SUBBHAREDDY
    Hi Thanks
     It works fine.
    Thankful for yyour timely reply.
    Thanks and regards
    Subbhareddy
