  3. How to come out of loop after x iterations.
  • Views 18550
SUBBHAREDDY
SUBBHAREDDY over 17 years ago
Hi Guys
 I am writing a skill code for for loop.Which executes statements  for 10 iterations.
I am keeping a check point at 8th iteration loop,and i want to come out of the loop,if my condition is satisfied.
I don't want to come out of my program,only come out of for loop only.
 Pls let me know ?
 Thanks and regards
Subbhareddy
  • SUBBHAREDDY
    Any help ?
    Andrew Beckett over 17 years ago
     First thing you could do is to just use a while loop instead:
    count=1 finished=nil while(count<=10 && !finished println(count) when(count==7 finished=t) count++ )
    Or you could use the prog() construct to allow you to return early:
    prog(() for(count 1 10 println(count) when(count==7 return()) ) ; for ) ; prog
    Personally I don't tend to like using the prog() approach - it leads to "spaghetti programming" where you've effectively got hidden jumps out of the code in the middle, which makes the flow of the program harder to understand.
  • SUBBHAREDDY
    Hi Andrew
    Thanks a lot,It works fine.
    Both are quite good.But in my way we can prefer prog method,i thinks so.
    Thanks and regards
    Subbhareddy
