  3. newbie SKILL question: how to create a via
  • Views 21195
chrisgregg
chrisgregg over 17 years ago
Hi everybody-- I'm writing some SKILL code to layout an adder. I need to place some vias to go from a metal 2 layer to a metal 1 layer, but I can't figure out how to do this. In the interactive layout, I'd just click Create-->Via (I'm using Cadence 6.1), and select VIA12_A and the other parameters, and then click where I want the via. But, looking through the Cadence docs, I can't seem to figure out how to do this with code. I found the "dbCreateVia" function, but it needs "d_viaDefId" for the second parameter, which I can't seem to get without first placing another via by hand and using the dbFindViaHeaderByName(cvid "VIA12_A") function. I'd like to do this without having to have that extra via to begin with. Thanks! -Chris
    Andrew Beckett over 17 years ago
    You need to use:
    tf=techGetTechFile(cvId) viaDef=techFindViaDefByName(tf "M3_M2") dbCreateVia(cvId viaDef 10:20 "R0") ; could also pass parameterList
  • chrisgregg
    Great -- thank you! -Chris
  • blankman
    blankman over 14 years ago
    Andrew, this has been very helpful, thank you.
    I am using the code below, and am seeing that even when the cellview is not editable it still places the via. Is there a workaround for this so that it only places it during edit mode?
    hiSetBindKey("Layout" "Shift<key>1" "dbCreateVia(geGetEditCellView() techFindViaDefByName(techGetTechFile(geGetEditCellView()) \"met3_met2_b\") geWindowToEditPoint(hiGetCurrentWindow() hiGetPoint(hiGetCurrentWindow())) \"R0\" list( list(\"cutRows\" 1) list(\"cutColumns\" 2) list(\"cutSpacing\" list(0.26 0.26)) list(\"layer1Enc\" list(0.06 0.06)) list(\"layer2Enc\" list(0.06 0.06)) list(\"cutWidth\" 0.26) list(\"cutHeight\" 0.26) list(\"originOffset\" list(0 0)))")
    Also, I am hoping to add this to a script along with bindkeys for IC5, and have the code select which function to assign based on what version of Cadence im running.
    eg if(cadence5 -> use ...leCreateContact
          if(cadence6 -> use ...dbCreateVia
    Is there a way this can be implemented? ie a way the code can identify the Cadence version?
    Thanks/Rgds,
    Brian.
     You could use geGetEditCellView()~>mode to determine whether in "r" mode or not. In OpenAccess, you're allowed to modify readonly cellViews - this is akin to "s" mode (scratch mode) in CDB - but the normal editing commands in the editor are disabled to avoid you accidentally changing things - but the low level functions still allow it.
    And to determine whether to use dbCreateVia - you could use dbGetDatabaseType() - this returns "OpenAccess" or "CDBA" (a misnomer, it should really return "CDB", but hey, we can't be perfect).
    Then you could do:
    if(dbGetDatabaseType()=="OpenAccess" then dbCreateVia(...) else leCreateContact(...))
    etc.
  • TeeBro
    TeeBro over 14 years ago
     Since I have more than one bindkey that changes between OA and CDB I have two bindkey sets.  I have some code in my
    .cdsinit that tests the database type and loads the appropriate set when I start. This may be helpful for you as well.
    ; Define bind keys for Layout, Schematic and Symbol editors
    if( (dbGetDatabaseType()=="CDBA")
       then
          printf( "Defining bind keys for schematic editor.\n" )
          loadi( "~/skill/schBindKeys.il" )
          printf( "Defining bindkeys for layout editor.\n" )
          loadi("~/skill/leBindKeys.il")
       else
          printf( "Defining bindkeys for OA schematic editor.\n" )
          loadi( "~/skill/schBindKeys_OA.il" )
          printf( "Defining bindkeys for OA layout editor.\n" )
          loadi( "~/skill/leBindKeys_OA.il")
    ); end if
  • blankman
    Works perfectly Andrew, Thanks!
