  3. A problem in spectre netlist generation
  • Views 16117
fudelong
fudelong over 17 years ago
Hi, everyone.
I met a problem when I tried to simulate my circuit after I modified it.When I click the "Netlist and Run", the status of ADE stopped on " Generate netlist...." . The process seems to be dead. And I have to kill it. If I create a new circuit, there will be no problem.
Anybody met this problem before? What should I do?
    Andrew Beckett over 17 years ago
    Did you look in the CIW to see if there were any error messages?
  • fudelong
    Thank you.
    I simulated the circuit again. There were not any error messages in the CIW.
    The CIW just stopped on
    " Delete psf data in.....
     generate netlist...
    Begin Incremental Netlisting ... "
    and I can't do any click but kill the process with kill command.
    This is the kind of thing that's probably best handled by going via customer support - log a service request at sourcelink.cadence.com .
    What version are you using? (what does it say on the Help->About... window for the version number, or type getVersion(t) in the CIW).
    How big is the design it's trying to netlist?
  • fudelong
    Thank you for your reply.
    The problem is resovled. I tried to rename my circuit and successed. There were four underlines in the name of circuit before that, maybe too many. However I don't know why ADE can generate netlist of my another circuit whose name has more than four underlines. Anyway, the prolem which troubles me long is resovled at last.
    Best wishes
