  3. how to draw shielding signal while taking care of drc?
  • Subscribers 152
  • Views 14786
Manu81
Manu81 over 17 years ago
How to draw shielding signals with user specified input shield signal space and width. I am trying to work with "lecreatepath". Can anyone help me with an example.
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
     The shielded path can be created with a rod path instead of just a regular path.To do it interactively you would use leHiCreateMPP and specify Subparts of Offset Subpaths for the left and right sheild and Enclosure Subpaths for the top and bottom sheild. You can save the template.
    Use rodCreatePath and specify the offset and enclosure subpaths to create it through SKILL. These are well documented and are pretty easy to use.
     Ted
