  3. i want to access value in enclosed quotation marks?
  • Views 15054
SUBBHAREDDY
SUBBHAREDDY over 17 years ago
Hi
I am not able to replace netName value in the below expression.
What would be causing the problem ?
 Pls help me out.
Ex : a = reddy
b="a"
i want to access a value enclosed with quotation marks.
How is it possible ?
###Code :
 foreach(netName myTable[key]
schCreateNetExpression( cv "[@netName:%:netName!]" wireid (15.75:y) "lowerCenter" "R0" "stick" 0.0625 )
    Andrew Beckett over 17 years ago
    Build the string with sprintf(). For example:
    sprintf(netExpr "[@%s:%%:%s!]" netName netName)
    And then use that in the schCreateNetExpression call:
      schCreateNetExpression( cv netExpr wireid (15.75:y) "lowerCenter" "R0" "stick" 0.0625 )
  • SUBBHAREDDY
    Hi Andrew
    Thanks a lot ,It works quite good.
