  3. SKILL versus SKILL++
  • Views 16263
gsimard
gsimard over 17 years ago
Hello everyone,
I am trying to use functions reserved to SKILL++ in my code but apparently it's not enabled on my installation. As an example, when I try this in the CIW:
(do ((x 0 x+1)) (print x))
Message: *Error* do: not supported in SKILL - do(((x 0 (x + 1))) print(x))
Quite clearly it's not expecting SKILL++ there. I could do without a do loop, but I'd really like to have access to what SKILL++ is about, that is, closures. For example:
(let ((x 0))
(defun total (y)
(setq x (plus x y))))
(total 3)
Message: *Error* eval: unbound variable - x
While in SKILL++ I would expect the result to be 3, x being a local state to the function total.
Is there a way to enable SKILL++ evaluation ?
Thank you,
Guillaume
    Andrew Beckett over 17 years ago
    In the CIW, if you type first:
    toplevel('ils)
    Then you can enter SKILL++ code. You can enter resume() to return to the SKILL toplevel.
    Or if the source is in a file, give it a suffix ".ils". Please read the chapters on SKILL++ in the SKILL Language User Guide - it's covered there - and in particular talks about calling SKILL from SKILL++ and vice versa, and how variables are shared between the two environments.
