  3. Comparing instances at certain coordinates
  • Views 15548
JMCaJHU
JMCaJHU over 17 years ago
Is there a way to compare instances at certain coordinates.  I am making a program to create an Or-Chain with a user provided number of inputs.  I have the inputs and the number of orgates created perfectly as well as the first level of routing.  However, as I progress to the second and third levels it would be easier to just use a while loop and create the next routing level based on the instances on a previous level.
Basically I am wondering if there is a command saying if the instance at (x,y) == " blahblah" then dbCreateInst(1 2 3).
Also if the command exists how is an instance compared? By name?
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
    Nothing like this exists off the shelf.
    There are several ways to do what you want. If you are building the array all at once, you can keep a list of the origin points (point cellName) so you can look up the cell which has been placed. Parse this list to decide your next cell.
     The second way is to use dbGetTrueOvelaps at the point of placement to find the placement at that point.
    Your comparison would be the cellName as the name is a logical instance name on the instance and not  corresponding to the cell.
     You may have to make some type of data structure which maps the previous placement to the next placement, I would probably make this an assoc list (placedCellName newCellName).
  • JMCaJHU
     Thanks. I think that keeping a list of each row would probably be the easiest method, since the routing of the next level depends on the entire previous row as opposed to just the point above it.  I'll look into the code for keeping a list and comparing instance names.
