  3. waveScan problem
  • Views 15889
waveScan problem
leongec
leongec over 17 years ago
 hi, i have some problems in using the wavescan, hope somebody can clarify for me.
i know how to set the axis attribute, as shown in the following
  wave3=getAsciiWave("temp1" 1 2)
drGetWaveformXVec(wave3)~>units="V"
drGetWaveformXVec(wave3)~>name="Vds"
drGetWaveformYVec(wave3)~>units="A"
my problem is, i have more than one data in the wavewindow,
it's not only wave3, but wave4 and wave5 , etc. i cant set the axis attribute with the code shown above, can anyone tell me how can i settle this?
thank you
leongec
    Andrew Beckett over 17 years ago
    You should be able to just do this:
    foreach(wave list(wave3 wave4 wave5)
      drGetWaveformXVec(wave)~>units="V"
      drGetWaveformXVec(wave)~>name="Vds"
      drGetWaveformYVec(wave)~>units="A"
    ) ; foreach
  • leongec
    hi Andrew, thanks for your reply! :) it's worked :):)
    I'm slightly confused, because I got another email from you (appears to be from the forum) saying that this didn't work:
    hi Andrew, thanks for your reply, but i cant do that by this method. The following is my code. Initially i get the data by using getAsciiWave, then i plot it in the Window and followed by the foreach to set the axis. After i execute my code.. the axis doesnt show... i have no ideal what 's wrong with it..
        newWindow();
        wave1=getAsciiWave("value1.txt" 1 2)
        plot(wave1)
        wave2=getAsciiWave("value2.txt" 1 2)
        plot(wave2)
        wave3=getAsciiWave("alue3.txt" 1 2)
        plot(wave3)
        wave4=getAsciiWave("value4.txt" 1 2)
        plot(wave4)
        wave5=getAsciiWave("value5.txt" 1 2)
        plot(wave5)
        foreach(wave list(wave1 wave2 wave3 wave4 wave5)
               drGetWaveformYVec(wave)~>units="A"    ) ; foreach
    That's because you need to change the attributes on the wave objects before you plot them. Probably easiest to remove calls to plot() after each getAsciiWave, and then add a call plot(wave) within the foreach loop.
