  3. How to check for schematic last save and last extracted...
  • Views 16471
How to check for schematic last save and last extracted in OA
vlau2
vlau2 over 17 years ago
I have a piece of SKILL code in cdba that used 2 database data:
cv~>lastSchematicExtraction
cv~>instanceLastChanged
which now returns nil in OA.
I want to check whether this schematic needs to checkNSave (extract) again.
What is the equivalent functions in OA?
  • skillUser
    skillUser over 17 years ago
    for the lastSchematicExtraction you can use the following function under OpenAccess:
    dbIsConnCurrent(cv)
    I think for the instancesLastChanged property, cellview counters are used instead - the function dbSetConnCurrent() can be used to bring the counter up to date.
    Lawrence.
    Andrew Beckett over 17 years ago
    By the way. dbIsConnCurrent() also works in CDB versions (it was added a few years ago), so the best thing is to always use that, and then it will work with either underlying database.
  • vlau2
    Yes,
    The function dbIsConnCurrent( cv ) is what I am looking for.
    -Vincent.
