  3. How to print the Monte Carlo iterations results
  • Subscribers 152
  • Views 17605
Micka
Micka over 17 years ago
I am pretty new with writing ocean scripts.
I have a task to run Monte Carlo simulations and print or save results of iterations.
For example, for each input of CMOS_S_BOX I have to find mean value of leackage cuurent,
but I want to have saved these iteration results in a file...Where am I wrong?::
ocnWaveformTool( 'wavescan )
simulator( 'spectre )
design(  "/home/scard/simulation/CMOSSbox_test_new_htype/spectre/schematic/netlist/netlist")
resultsDir( "/home/scard/simulation/CMOSSbox_test_new_htype/spectre/schematic" )
definitionFile(
    "models.scs"
analysis('tran ?stop "1u" )
desVar(   "tclk" 1u )
desVar(   "j" 0 )
desVar(   "del" 200n )
option( 'temp  "25.0"
 'iabstol  "1e-14"
 'vabstol  "1e-8"
 'reltol  "1e-6"
save( 'i "/V4/PLUS" )
temp( 25.0 )
MCresults = outfile( "/home/scard/results/SBOX_mc_htypefinal/sbox_mc_results.txt" "w")
monteCarlo( ?numIters "10" ?startIter "1" ?analysisVariation 'mismatch ?sweptParam "None" ?sweptParamVals "25" ?saveData t ?nomRun "yes" ?append nil)
monteExpr( "leak" "-average(clip(i(\"/V4/PLUS\" ?result \"tran-tran\") 5e-07 1e-06))" )
monteRun()
Imc_mean = average(-average(clip(i("/V4/PLUS" ?result "tran") 5e-07 1e-06)))
fprintf( MCresults "%3.4f \n" Imc_mean*1e9 );
close(MCresults);
MCresults = outfile( "/home/scard/results/SBOX_mc_htypefinal/sbox_mc_results.txt" "a")
close(MCresults)
In this bolded area I am obviously doing mistakes, because in the mcdata file I get same results for all 10 iterations, but running an usual MC simulation I am getting different values...HELP,  PLEASE!!!
Thank you...
    Andrew Beckett over 17 years ago
    I think I answered this in the other posting, but you need to worry about aliased versus non-aliased results names.
    Look in <ICinstDir>/doc/aatoolsuser/aatoolsuser.pdf and search for the word "aliased". You'll find a section (around page 94 in IC5141 doc) which talks about "Data Access Function Types" and on the next page "Data Name Aliasing". Both of those explain this pretty well.
  • Micka
    Ok, here is the problem:
    monteRun()
    fprintf( MCresults "%d \t\t %3.4f \t\t %2.3f \n" j Imc_mean*1e9 Imc_std*1e9 );
    close(MCresults);
    close(MCresults)
    Ok, with this bolded command I get the average value of 400 MC runs, and I wana have in sbox_mc_results.txt results of all 400 MC runs.
    How do I achieve that?
    If I put only
    Imc_mean = -average(clip(i("/V4/PLUS" ?result "tran") 5e-07 1e-06))
    it gives me like a result some strange letters.
     So, my question is what instruction do I have to use, so I could save average results of all 400 MC iterations???
    Thank you...
    What you'll get that way is something like srrWave:NNNN or drwave:NNNN depending on the version you're using.
    If you use the ocnPrint() function, you can print out the values of waveform objects. So I suspect that's what you want.
    Or you could use the abStats.il code I pointed you to in a previous post, and then do:
    mcData=abReadMonteData(strcat(openResults() "/monteCarlo"))
    valtab=mcData->datatab["leak"]
    for(i 0  mcData->N - 1
      fprintf(MCresults "%g\n" valtab[i])
    ) ; for
  • AMRUT
    AMRUT over 15 years ago
    Even I am facing the similar problem. I want to save the iteration values i.e. using iterVsValue command , in monte carlo simulation.
    I need to save it in a file, how can I do that?
