  3. Bindkeys to switch input for form
  • Subscribers 152
  • Views 16767
kbhow
kbhow over 17 years ago
 I'm looking for a skill code which able to switch the input string for the form by using bindkeys.
For example,  i created a form for some rule checks. And user are able to input the data in the reserve string field. Upon finish, all form's data will be store in a table. When next time user invoke the form again, they can use bindkey <key> up and <key> down to check for history.
    Andrew Beckett over 17 years ago
    You can't define bindkeys for forms, but perhaps instead you want to use a "combo box" widget?  This is created using hiCreateComboField() - and allows both a list of cyclic choices (which could be your history) and a type in field.
  • ahamlett
    ahamlett over 17 years ago
    If you just want to change a string field in a form with a bind key, you can set the bind key to:
    'myForm->myStringField->value = "new string value"
    changing 'myForm to your form symbol and myStringField to the name of your string field in the form.
    If you want to restore a string that was previously reserved or saved by the form into your database then write a function to set 'myForm->myStringField->value to the saved string and call that function from the bindkey such as:
    myFunction("up") ; moves up through history
    myFunction("down") ; moves down through history
  • rajeshcad
    rajeshcad over 17 years ago
    Entry part can be string field. Implement the history part as a report field (hiCreateReportField). It will be a scrollable, sortable field.
  • kbhow
    Hi all,
     Thanks for the prompts reply.  : -)
    Andrew do hit the point that i'm facing. When a form is up, the bindkeys will not working unless the active window is switch to other window. Especially when i trying to use bindkey to change the string's data.
    Let me try on hiCreateComboField and hiCreateReportField.
    Thanks. Cheer
  • kbhow
    Cool...
    It works. I create a function and assign it to <key>up and <key>down to callback for input history. And use function hiCreateComboField to create the string field. It works perfectly.
    Thanks guy.
