  3. need to browse the device categories using itkDB
  • Views 15687
Mikhail111
Mikhail111 over 17 years ago
I need to browse the device categories in our automation tool using itkDB. Please suggest any appropriate way to do it. I know how to do it using SKILL but the task is to write the same in C++. Unfortunately I could not find in itkDB header any function like SKILL ddCat...(). What function set should I use? Where can I get an example of category browser (need to extract whole category tree)?
Thanks in advance.
Mike
    Andrew Beckett over 17 years ago
    There are no public ITK DB functions for accessing Categories. If you want something like that, you should contact Cadence Customer Support and request these be added as an enhancement request.
    Best Regards,
  • Mikhail111
    > Best Regards,
    > Andrew.
    > You received this email because you subscribed to notifications for
    > the Cadence Custom IC SKILL Forum. To unsubscribe, log in, go to
    > forums, and change your forum subscriptions.
    > http://www.cadence.com/community/forums/ForumSubscriptions.aspx
    Thank you very much. In such case I'll try to make it myself.
    Best regards,
    Mike
