  3. setting bindkey in IC6
  • Views 15802
vincentmt
vincentmt over 17 years ago
Hi all,
i am wonder how can we set bindkey for the "rule move" function in IC6 toolbox? which function i show refer?
    Andrew Beckett over 17 years ago
    You can use Options->Log Filter and turn everything on so you can see what SKILL function gets invoked when you press the icon. Or alternatively you can look at <ICinstDir>/tools/dfII/etc/tools/menus/layToolbox.menus and see the definition.
    The bindkey would be for  _leTbCommand( "_leTbRuleMove()" )
  • vincentmt
     thanks Andrew, it's help....
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
     The toolbox is used in the applications layout and layoutXL so you probably have to define the bindkey (hiSetBindKe) for both applications.
  • kbhow
    kbhow over 17 years ago
    In additional, the turbo toolbox has to be in active mode. Or else, the bindkey will not working. Toolbox have to instantiate once before using.
