  3. Print Cursor co-ordinates
  • Subscribers 150
  • Views 16902
bharath2k4er
bharath2k4er over 17 years ago
          I want to print the co-ordinates of the cursor pointer...for example: I have 5 clicks done in my layout. My output should be 5 co-ordinates written in a new file called "coord"
Pls give me some suggestions...
Bharath
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
     There are a couple of ways to do this:
     enterPoints - This enter function can prompt for points and use the callback to enter the information into a file.
     hiGetCommandPoint - gets the location of the pointer at the last click, place in a loop and as the user clicks the points, the points will be returned.
    3 - there are 3 ways to do this:
     hiGetPoint - Gets the current xy location of the cursor. Does not need a mouse click.
  • skillUser
    skillUser over 17 years ago
    Hi Bharath,
    In addition to what Ted has said, you will also probably want to use the outfile(), fprintf() and close()  SKILL functions for opening, writing to and closing the file respectively. Assuming that the variable coordlist contains the coordinates gathered from the layout, you might do something like the following:
    when(fptr = outfile("coord")
     foreach(coord coordlist
       fprintf(fptr "%L" coord)
     close(fptr)
    ); when the file can be opened for writing
    Best regards,
    Lawrence.
  • kbhow
    kbhow over 17 years ago
    Hi Bharath,
    I believe this script may helps.
    procedure( GetCursorCoord( @key
    (numbOfPoints 5)
    (fileName "CursorCoord.log"))
    let((messages pt fp)
    ; Create a message to prompts
    for( i 1 5
    messages = cons(sprintf(nil "Enter %d point" i) messages)
    ; Get enter points from user
    points = enterPoints(
    ?prompts reverse(messages)
    ?wantPoints numbOfPoints
    ; Write the coordinate to a file
    if( (fp = outfile(fileName)) then
    foreach( pt points
    fprintf(fp "Coord -> %L" pt)
    close(fp)
    else
    warn("Failed to open file %L\n" fileName)
    );let
    );proc
    How
