  3. How do I avoid the renaming of long net names during netlisting...
  • Replies 13
  • Views 10532
How do I avoid the renaming of long net names during netlisting/flattening?
skillet
skillet over 17 years ago
I've been able to read a Verilog file into DFII via ihdl to create a netlist view. My intent is to create an autoLayout view, so I go to "Tools --> Floorplan/Netlist in my window that shows me the netlist view and then go to the Hierarchy Browser. After preparing all my settings I click on "Hierarchy ---> Generate Physical Hierarchy". Eventually I get my autoLayout view.
Everything seems hunky-dory, except that some nets have gotten renamed to something like "_LoNgNeTnAmE108(123)". It appears the flattener didn't like the original net name (even though it's not really that much longer and I don't think there are restrictions on net names in the CDBA, or maybe it's 256 bytes but I'm nowhere near that length).
The problem now is that I can't correlate some of my nets in the Verilog netlist with the nets in my floorplan.
I haven't found any documentation on net renaming or the generation of a mapping file that would help me sort this out. There's nothing to be found in the adpFlatten directory that I could take advantage of.
Any comments what else I could try to remedy this problem? I need my symbolic netlist match exactly my Verilog netlist. BTW, my netlist is flat. In other words, there is no hierarchy involved. It's just a bunch of blocks (represented by abstracts) interconnected by a bunch of nets.
The DFII version I'm using is IC5.1 on Solaris (Sparc V9).
  • skillUser
    skillUser over 17 years ago
    I think that I missed an important point - the above .cdsenv setting is used by VerilogIn when running from the GUI, but if you are running "ihdl" from the command line, then you will need to pass the option to ihdl through a setting in the parameters file, e.g.
    maxNetNameLength := 4000
     This setting was added from about USR3 onwards I believe, so the version that you are using should understand and use it.
    Also I noticed in your version strings that you might be running in 64-bit mode; I'm not sure this will work for ihdl, so you might want to ensure that you turn off 64-bit mode for ihdl from the command line.
    Hope this helps!
    Lawrence.
  • skillet
    I can't get it to work. I've tried our latest Solaris version (sub-version 5.10.41_USR6.127.29) and I tried our latest Linux version (also sub-version 5.10.41_USR6.127.29). I've tried 64b and 32b versions. Neither the GUI-based nor the standalone versions work. I've put most of my hope into the standalone version as I at least know that it reads my parameter file where I can explicitely state
    max_net_name_length := 4000
    Note that you stated in your last post
    but according to the Cadence documentation it should be the former expression. Just to be sure, I tried your expression as well but it isn't accepted by ihdl.
    I use the following command and data files with the purpose to create a netlist view:
    command:
    ihdllnx86 -f ihdl_files -p paramFile <topRTL>.v
    paramFile:
    dest_sch_lib := <destLibName>
    ref_lib_list := basic, <
    otherLibs>
    import_if_exists := 1
    import_cells := 0
    import_lib_cells := 0
    structural_views := 6
    schematic_view_name := schematic
    functional_view_name := functional
    netlist_view_name := netlist
    symbol_view_name := symbol
    log_file_name := ./verilogIn.log
    map_file_name := ./verilogIn.map.table
    work_area := /home/<
    user>/verilogIn
    power_net := vdd
    ground_net := vss
    create_map_table := 1
    sheet_symbol := Asize
    page_row_limit := 512
    page_col_limit := 256
    label_height := 12
    line_line_spacing := 0.2
    line_component_spacing := 0.5
    density_level := 0
    client := synthesis
    alias_module := cds_alias
    cont_assign_symbol := basic patch symbol
    I don't see any other avenue to get this to work. No matter what approach I use on Solaris, it always dies with a segmentation fault.
  • skillUser
    Oops, sorry about the mistake in my post.
    I think that you may need to file a Service Request with customer support; this may be a data specific case, or something that was missed in the fixes, and so Cadence R&D may need to see this in order for there to be progress on the issue.
    Sorry!
    Lawrence.
