  3. How to select and delete all the floating nets in a cel...
  • Replies 7
  • Views 22856
How to select and delete all the floating nets in a cell
SUBBHAREDDY
SUBBHAREDDY over 17 years ago
Hi
How to select and delete all the floating nets in a cell,at a time ,and delete all the floating nets.
 Pls let me know
Thanks and regards
Subbhareddy
    Andrew Beckett over 17 years ago
    What is your definition of floating?
    Is this layout or schematic?
  • SUBBHAREDDY
    in schematic only
    means just it is a wire ,i.e empty wire drawn in the view.
    In a cell if it finds wire drawn not connected to any of the pins or nets or instances,
    i want to delete like that type of wires.
    Thanks and regads
    Subbhareddy
    floaters=setof(net cvId~>nets !(net~>instTerms || net~>term))
    foreach(floater floaters
      foreach(fig floater~>figs dbDeleteObject(fig))
      dbDeleteObject(floater)
    Should do it. cvId is the database Id of the cellView you're cleaning up.
  • Umashetty
    Umashetty over 6 years ago in reply to Andrew Beckett
    Hi Andrew ,
    Can please send the code for Selecting and deleting the floating net(path) in layout.
    Thanks and Regards,
    Uma
    Andrew Beckett over 6 years ago in reply to Umashetty
    If the layout was done with Virtuoso Layout Suite XL (and has connectivity), then I think the code above should work for layout too.
  • Umashetty
    Layout is done with Virtuoso Layout suite L.
    Thanks and Regards,
    Uma
    That's not going to be easy then. I don't have any code to do that - you'd either need to write code to do shape chasing to determine whether anything is connected, or extract it using VLS XL functionality.
