  3. How to change library name & cell name by SKILL
  • Subscribers 150
  • Views 8899
ajuvolkov
ajuvolkov over 17 years ago
Hello.
I need to change library name and cell name in all instances of the project.
See below simple example, when I attempt to change this parameter:
w = hiGetCurrentWindow()
cv = geGetWindowCellView(w)
inst=nthelem(1 cv~>instances)
inst~>libName="NEW_PROCESS"
but this returned:
*Error* setSGq: dbSetq: Can not set attribute - libName
How can I change this parameter?
    Andrew Beckett over 17 years ago
    You need to change the master attribute.
    For example:
    master=dbOpenCellViewByType("NEW_PROCESS" inst~>cellName inst~>viewName)
    inst~>master=master
  • skillUser
    skillUser over 17 years ago
    In addition to what Andrew has said, it may be more efficient to change the instHeader for the instances that you want to all change to a new master.  Find the instHeader, something like:
    ih = car(setof( instHead cv~>instHeaders instHead~>libName == "origLibName" && instHead~>cellName == "origCellName")
    dbSetInstHeaderMasterName(ih "NEW_PROCESS" ih~>cellName ih~>viewName)
    [I have not tested the above code, but it should work].  If the cell names are different, then you might want to have a mapping table for the from-to name mappings.  There are a few solutions in SourceLink for doing this too, for example:
    Solution 11300258
    Solution 11256326
    Solution 11406650
    Solution 11330954
    Solution 11330948
    Solution 11330942
    Take a look at the last two in particular, since they use the instHeader approach. Many of these will change multiple cells, or even a whole library. Did you look on SourceLink?
    If you need to re-reference all the cells to the same new library, why don't you use Edit->Rename Reference Library from the Library Manager menus?
    Lawrence.
