  3. Pin "VDD": floating input/output
  • Views 7010
SUBBHAREDDY
SUBBHAREDDY over 17 years ago
Hi
In my schematic, For an inverter A(input),ZN(output),VDD(inputOutput), VSS(inputOutput) pins are present.
Through skill code i removed "VDD" and instantiated "vdd_inherit" symbol.
when i do check and save i used to get the below warning :
Here is the code i had written :
 pindb=car(setof(x cv~>instances (x~>pin~>term~>name=="VDD")))
x_cord = car(pindb~>xy)
y_cord = cadr(pindb~>xy)
dbDeleteObject(pindb)
symbolId = dbOpenCellViewByType("basic"  "vss_inherit" "symbol" nil "r")
schCreateInst(cv symbolId nil x_cord:y_cord "R0")
schCheck(cv)
Warning: Pin "VDD": floating input/output.
Pls let me know what would be the problem
Thanks and regards
Subbhareddy
    Andrew Beckett over 17 years ago
    What version are you using (and subversion)? I tried this in both IC5141 and IC613 and it worked in both... (latest ISR in both cases).
