  3. pCell skill for beginners
  • Replies 21
  • Subscribers 154
  • Views 42124
stuso
stuso over 17 years ago
i'd like some advice for creating my first simple pCell from skill. I have no skill experience so i'm looking for a good place to start.
My ultimate aim (for now) is to create a rectangular via array with X and Y stretch handles. For example you have M1->M4(the top & bottom layers would be parameters) that you can stretch in X or Y and it fills with the max vias allowed by spacing rules. However to begin with i'd be happy to create a parameterised rectangle of M1 that i can stretch in one direction & take it from there.
Pointers to on-line tutorials and very simple examples would be great, right now i am blindly searching around source-link.
Stu
  • skillUser
    skillUser over 17 years ago
    Oops, I forgot to say that the CDF callback can be used to provide feedback to the user, as well as changing the value, e.g. to clamp it at the minimum or maximum value so that the CDF callback enforces a valid range, as well as perhaps printing a message in the CIW or popping up a dialog box (although the latter tends to annoy users since you have to dismiss it).
    Lawrence.
  • Messi
    Messi over 15 years ago
     I am new in pcell creation.I need help.I wnt code which creates pcell which takes more then 3 layers as its parameters.Also the layer purpose pair i would like to have as "fill".Can anyone help me out.
     Messi
  • NewStudent
    NewStudent over 15 years ago
    I am  new to skill.I am trying to use your program to draw metal rectangle and labels.What command should I give in CIW window .I tried CCScreateBoxAndLabels( 1 0.6 1) its complaning about dnn being database object ?? I scanned through the sklanguser manual but could not get the answere.
    Thanks.
    The precise error message would have been:
    CCScreateBoxAndLabels( 1 0.6 1) *Error* CCScreateBoxAndLabels: argument #1 should be a database object (type template = "dnn") - 1
    The "dnn" is the argument to the function definition which adds type-checking. It is checking that the first argument is a database object, and the next two are numbers.
    I'm not sure why you passed 1 as the first argument, that makes no sense. It is expecting a cellView id, as returned by geGetEditCellView() (if you have a layout window open), or from dbOpenCellViewByType("mylib" "mycell" "layout" "maskLayout" "a")
    So for example:
    cv=geGetEditCellView()
    CCScreateBoxAndLabels(cv 0.6 1)
  • NewStudent
    Thanks Andrew. I started with top-down approach with skill rather then bottom-up.I thought it was easier way for me to learn skill coding.
    What I mean by that is :I have written skill code that can generate array and labels from already layed out cell.
    I had few questions regarding this :
    Is there any way I can generate skill code from layout I have? I had this question because I wanted generic way for generating text from lower level layout cells on top level cells.
    Eg : If I have x cell which has 10 - y cells arrayed.I want labels from y cells to be replicated at x level with _1,_2,_3 .
    I know and I already did skill code for this but I need a standard way ( single code) that can do it for any cell array I want .This without hardcoding the labels and pins in my skill script.
    For this reason wanted to check if there is some way I can generate skill code from layout of lower level.This way I can make my standard skill code point to  skill code generated from layout to pass on the pins labels etc.
    I am really struggling over making standard code for all the array combinations without having hard coded labels or pins.Please suggest me if you have any other better way or idea regarding this.
    Sapna.
  • satishbabub
    satishbabub over 13 years ago
    Hello Lawrence ,
    I would really appreciate if you could take a look at the following code and the errors im getting .
    ; -- Init
    (define (jfet_fno_SKILL p_libname p_cellname) ; (pcDefinePCell
        (list
          (ddGetObj (eval p_libname) (eval p_cellname)) "layout"
    ; -- Params
          (W         float       10.0)
          (L          float       10.0)
          (PWpb       float  -0.20)
          (PDNpb            float   0.0)
          (PDPtop           boolean t)
          (PDPext           boolean t)
          (PDNcover   boolean t)
          (CELLHtop   boolean t)
    ; -- Main
        (let
          (pcMember pcStretchGroup
              stretchOffsetX stretchOffsetY pcLib pcMaster pcInst
              pcTerm pcPin pcPinName pcNet pcTermNet
              pcNetName pcTermNetName pcMosaicInst tpcParameters pcParamProp
              pcStep pcStepX pcStepY pcRepeat pcRepeatX
              pcRepeatY pcIndexX pcIndexY pcLayer pcPurpose
              pcLabelText pcLabelHeight pcPropText pcParamText pcCoords
              pcPathWidth pcPolygonMargin
          (setq pcLib
              (getSGq pcCellView lib)
          (setq pcParameters
              (getSGq
                (getSGq pcCellView parameters) value
          (dbReplaceProp pcCellView "viewSubType" "string" "maskLayoutParamCell")
    ; -- Init layer names ----------------------------------------------------------
          lay_DIFF    = techGetLP(pcLib `("diff"   "drawing"))~>number
          lay_HV            = techGetLP(pcLib `("diff"   "hv"     ))~>number
          lay_POLY    = techGetLP(pcLib `("poly"   "drawing"))~>number
          lay_PWELL   = techGetLP(pcLib `("pwell"  "drawing"))~>number
          lay_NWELL   = techGetLP(pcLib `("nwell"  "drawing"))~>number
          lay_PDN           = techGetLP(pcLib `("nps"    "drawing"))~>number
          lay_PDP           = techGetLP(pcLib `("pps"    "drawing"))~>number
          lay_NSDM    = techGetLP(pcLib `("nsdm"   "drawing"))~>number
          lay_CELLM   = techGetLP(pcLib `("cellm"  "drawing"))~>number
          lay_CELLTX  = techGetLP(pcLib `("celltx" "drawing"))~>number
          lay_CELLH   = techGetLP(pcLib `("cellh"  "drawing"))~>number
          lay_CELLRS  = techGetLP(pcLib `("cellrs" "drawing"))~>number
          lay_CIRPO   = techGetLP(pcLib `("cirpo"  "drawing"))~>number
          lay_PIXID   = techGetLP(pcLib `("areaid" "pixel"))    ~>number
          lay_M1            = techGetLP(pcLib `("met1"   "drawing"))~>number
          lay_TEXT    = techGetLP(pcLib `("text"   "drawing"))~>number
    ; -- Defaults ------------------------------------------------------------------
          tech_lib          = "ts018c0702tc_dv"
          Wmax              = 20.0
          Lmax              = 20.0
          cor_size          = 0.15
          ref_x             =  0.0
          ref_y             = -L/2
    ; -- Init suncells -------------------------------------------------------------
          (setq pcMaster_DFM1 (dbOpenCellViewByType tech_lib "DFM1" "symbolic" "maskLayout"))
          (setq pcMaster_TPM1 (dbOpenCellViewByType tech_lib "TPM1" "symbolic" "maskLayout"))
    ; -- Metal 1 connection --------------------------------------------------------
          (setq pcInst
              (dbCreatePolygon pcCellView
                (list lay_M1 "drawing")
                (list
                    (range  ref_x+1.0                           ref_y+2.4+L)
                    (range  ref_x-1.0                           ref_y+2.4+L)
                    (range  ref_x-1.0                           10)
                    (range  ref_x+1.0                           10)
          (setq pcInst
                (list
                    (range  ref_x+1.0                           ref_y-2.4)
                    (range  ref_x-1.0                           ref_y-2.4)
                    (range  ref_x-1.0                           -10)
                    (range  ref_x+1.0                           -10)
    ; -- Contacts ------------------------------------------------------------------
          (numb_of_cont   = (round (Wmax/0.47))-1)
          (cell_coord     = (range ref_x-numb_of_cont/2.0*0.47 ref_y-2.5))
          (dbCreateParamInst pcCellView pcMaster_DFM1 nil cell_coord "R0" 1  list(
                      list( "column" "integer" numb_of_cont)
          (cell_coord     = (range ref_x-numb_of_cont/2.0*0.47 ref_y+2.5+L))
          (dbCreateParamInst pcCellView pcMaster_DFM1 nil cell_coord "MX" 1  list(
    ; -- Tap -----------------------------------------------------------------------
          (numb_of_cont   = (round ((Lmax+5)/0.47))-1)
          (cell_coord     = (range ref_x-(Wmax/2.0+4.0) -Lmax/2-2.5))
          (dbCreateParamInst pcCellView pcMaster_TPM1 nil cell_coord "R0" 1  list(
                      list( "row" "integer" numb_of_cont)
          (cell_coord     = (range ref_x+(Wmax/2.0+34.0) -Lmax/2-2.5))
    ; -- Diff ----------------------------------------------------------------------
          if((equal PDPext nil)
          then
          ; -- Do not ADD PDP extentions
                PDPext_diff = 0.0
          else
          ; -- ADD PDP extentions
                PDPext_diff = 1.3
          (setq pcInst
                (list lay_DIFF "drawing")
                (list
                    (range  ref_x+W/2.0                         ref_y+cor_size)
                    (range  ref_x+W/2.0+cor_size                ref_y+0.0)
                    (range  ref_x+Wmax/2.0+PDPext_diff          ref_y+0.0)
                    (range  ref_x+Wmax/2.0+PDPext_diff          ref_y-1.0)
                    (range  ref_x+Wmax/2.0                      ref_y-1.0)
                    (range  ref_x+Wmax/2.0                      ref_y-2.5)
                    (range  ref_x-Wmax/2.0                      ref_y-2.5)
                    (range  ref_x-Wmax/2.0                      ref_y-1.0)
                    (range  ref_x-Wmax/2.0-PDPext_diff          ref_y-1.0)
                    (range  ref_x-Wmax/2.0-PDPext_diff          ref_y+0.0)
                    (range  ref_x-W/2.0-cor_size                ref_y+0.0)
                    (range  ref_x-W/2.0                         ref_y+cor_size)
                    (range  ref_x-W/2.0                         ref_y+0.0+L-cor_size)
                    (range  ref_x-W/2.0-cor_size                ref_y+0.0+L)
                    (range  ref_x-Wmax/2.0-PDPext_diff          ref_y+0.0+L)
                    (range  ref_x-Wmax/2.0-PDPext_diff          ref_y+1.0+L)
                    (range  ref_x-Wmax/2.0                      ref_y+1.0+L)
                    (range  ref_x-Wmax/2.0                      ref_y+2.5+L)
                    (range  ref_x+Wmax/2.0                      ref_y+2.5+L)
                    (range  ref_x+Wmax/2.0               ref_y+1.0+L)
                    (range  ref_x+Wmax/2.0+PDPext_diff          ref_y+1.0+L)
                    (range  ref_x+Wmax/2.0+PDPext_diff          ref_y+0.0+L)
                    (range  ref_x+W/2.0+cor_size                ref_y+0.0+L)
                    (range  ref_x+W/2.0                         ref_y+0.0+L-cor_size)
    ; -- PWELL ----------------------------------------------------------------------
          (setq pcInst
                (list lay_PWELL "drawing")
                (list
                    (range  ref_x+PWpb+W/2.0              ref_y+PWpb+cor_size)
                    (range  40.0                                ref_y+PWpb+cor_size)
                    (range  40.0                                0.0-40.0)
                    (range  40.0                          0.0+40.0)
                    (range  -40.0                               0.0+40.0)
                    (range  -40.0                               0.0-40.0)
                    (range  ref_x+PWpb+W/2.0+cor_size           ref_y+PWpb+0.0)
                    (range  ref_x+PWpb+Wmax/2.0           ref_y+PWpb+0.0)
                    (range  ref_x+PWpb+Wmax/2.0                       ref_y-PWpb-2.5)
                    (range  ref_x-PWpb-Wmax/2.0                 ref_y-PWpb-2.5)
                    (range  ref_x-PWpb-Wmax/2.0                 ref_y+PWpb+0.0)
                    (range  ref_x-PWpb-W/2.0-cor_size           ref_y+PWpb+0.0)
                    (range  ref_x-PWpb-W/2.0                  ref_y+PWpb+cor_size)
                    (range  ref_x-PWpb-W/2.0                    ref_y-PWpb+0.0+L-cor_size)
                    (range  ref_x-PWpb-W/2.0-cor_size           ref_y-PWpb+0.0+L)
                    (range  ref_x-PWpb-Wmax/2.0          ref_y-PWpb+0.0+L)
                    (range  ref_x-PWpb-Wmax/2.0                 ref_y+PWpb+2.5+L)
                    (range  ref_x+PWpb+Wmax/2.0                 ref_y+PWpb+2.5+L)
                    (range  ref_x+PWpb+Wmax/2.0                       ref_y-PWpb+0.0+L)
                    (range  ref_x+PWpb+W/2.0+cor_size           ref_y-PWpb+0.0+L)
                    (range  ref_x+PWpb+W/2.0                    ref_y-PWpb+0.0+L-cor_size)
    ; -- PDN ----------------------------------------------------------------------
          if((equal PDNcover t)
          then
          (setq pcInst
                (list lay_PDN "drawing")
                (list
                    (range  ref_x+Wmax/2.0+0.3                  ref_y-2.5-0.3)
                    (range  ref_x-Wmax/2.0-0.3                  ref_y-2.5-0.3)
                    (range  ref_x-Wmax/2.0-0.3                  ref_y+2.5+0.3+L)
                    (range  ref_x+Wmax/2.0+0.3                  ref_y+2.5+0.3+L)
          else
          (setq pcInst
                (list
                    (range  ref_x+PDNpb+W/2.0                   ref_y+PDNpb+cor_size)
                    (range  ref_x+PDNpb+W/2.0+cor_size          ref_y+PDNpb+0.0)
                    (range  ref_x+PDNpb+Wmax/2.0          ref_y+PDNpb+0.0)
                    (range  ref_x+PDNpb+Wmax/2.0          ref_y-PDNpb-2.5)
                    (range  ref_x-PDNpb-Wmax/2.0                ref_y-PDNpb-2.5)
                    (range  ref_x-PDNpb-Wmax/2.0                ref_y+PDNpb+0.0)
                    (range  ref_x-PDNpb-W/2.0-cor_size          ref_y+PDNpb+0.0)
                    (range  ref_x-PDNpb-W/2.0                 ref_y+PDNpb+cor_size)
                    (range  ref_x-PDNpb-W/2.0                   ref_y-PDNpb+0.0+L-cor_size)
                    (range  ref_x-PDNpb-W/2.0-cor_size          ref_y-PDNpb+0.0+L)
                    (range  ref_x-PDNpb-Wmax/2.0                ref_y-PDNpb+0.0+L)
                    (range  ref_x-PDNpb-Wmax/2.0                ref_y+PDNpb+2.5+L)
                    (range  ref_x+PDNpb+Wmax/2.0          ref_y+PDNpb+2.5+L)
                    (range  ref_x+PDNpb+Wmax/2.0          ref_y-PDNpb+0.0+L)
                    (range  ref_x+PDNpb+W/2.0+cor_size          ref_y-PDNpb+0.0+L)
                    (range  ref_x+PDNpb+W/2.0                   ref_y-PDNpb+0.0+L-cor_size)
    ; -- PDP ----------------------------------------------------------------------
          if((equal PDPtop t)
          then
          (setq pcInst
                (list lay_PDP "drawing")
                (list
                    (range  ref_x+Wmax/2.0+0.3+PDPext_diff      ref_y-1.0-0.3)
                    (range  ref_x-Wmax/2.0-0.3-PDPext_diff      ref_y-1.0-0.3)
                    (range  ref_x-Wmax/2.0-0.3-PDPext_diff      ref_y+1.0+0.3+L)
                    (range  ref_x+Wmax/2.0+0.3+PDPext_diff      ref_y+1.0+0.3+L)
    ; -- CELLH ----------------------------------------------------------------------
          if((equal CELLHtop t)
          then
          (setq pcInst
                (list lay_CELLH "drawing")
                (list
                    (range  ref_x+Wmax/2.0+0.3+PDPext_diff+0.15 ref_y-1.0-0.3-0.15)
                    (range  ref_x-Wmax/2.0-0.3-PDPext_diff-0.15 ref_y-1.0-0.3-0.15)
                    (range  ref_x-Wmax/2.0-0.3-PDPext_diff-0.15 ref_y+1.0+0.3+L+0.15)
                    (range  ref_x+Wmax/2.0+0.3+PDPext_diff+0.15 ref_y+1.0+0.3+L+0.15)
    ; -- DIFF HV ----------------------------------------------------------------------
          (setq pcInst
                (list lay_DIFF "hv")
                (list
                    (range  40.0                                -40.0)
                    (range  40.0                           40.0)
                    (range  -40.0                                40.0)
                    (range  -40.0                               -40.0)
    ; -- CELLM ----------------------------------------------------------------------
          (setq pcInst
                (list lay_CELLM "drawing")
                (list
                    (range  40.0                                -40.0)
                    (range  40.0                           40.0)
                    (range  -40.0                                40.0)
                    (range  -40.0                               -40.0)
    ; -- CIRPO ----------------------------------------------------------------------
          (setq pcInst
                (list lay_CIRPO "drawing")
                (list
                    (range   40.3                               -40.3)
                    (range   40.3                                40.3)
                    (range  -40.3                                40.3)
                    (range  -40.3                               -40.3)
    ; -- AREAID PIX ----------------------------------------------------------------------
          (setq pcInst
                (list lay_PIXID "pixel")
                (list
                    (range  40.0                                -40.0)
                    (range  40.0                           40.0)
                    (range  -40.0                                40.0)
                    (range  -40.0                               -40.0)
    ; -- label ----------------------------------------------------------------------
          (cell_coord     = (range ref_x ref_y))
          (dbCreateLabel pcCellView lay_TEXT cell_coord
                (sprintf nil "W=%.3f\nL=%.3f\nPWpb=%.3f\nPDNpb=%.3f\nPDPtop=%L\nPDPext=%L\nPDNcover=%L\nCELLHtop=%L"
                W L PWpb PDNpb PDPtop PDPext PDNcover CELLHtop  )
                "lowerLeft" "R0" "stick" 1)
    I tried to load the skill code using
    load("/home/fg3z7q/Desktop/jfet_fno_SKILL.il")
    function jfet_fno_SKILL redefined
    t
    and when i call the function
    jfet_fno_SKILL "fno_ts018_etest" "jfet_fno_SKILL"
    it gives a waring stating that
    *WARNING* Invalid libId - dd:0x19a9bad4
    *WARNING* Invalid view name - nil
    nil
    Here I created a library named fno_ts018_etest and cell view named jfet_fno_SKILL before loading the skill.
    Im a beginer and I appreciate any sort of help regarding this
    Satish
    There's a lot of code to try out there to debug this - I took a quick look, but it would be far easier to try it out as is - without your technology file, I'd have to go through and change all the layer/purpose names to something I have.
    So, can you either post the technology file, or if it's not yours to post, can you say which Foundry PDK you're using?
  • ztzg
    ztzg over 13 years ago
    Hello Satishbabub,
    One thing I noticed is that you commented the pcDefinePCell form to
    replace it with a (define (jfet... ) ...) procedure.
    That is not a bad idea, but is not sufficient; pcDefinePCell has
    "special" evaluation semantics.
    In the code you posted, (list (ddGetObj ...)) won't cause pcCellView to
    be bound in the body. Similarly, the second argument of pcDefinePCell
    is a list of parameters, and cannot be evaluated as a normal expression.
    You should be able to fix that by adding another let() binding with
    "fake" pcell variables around the body. Have a look at the (UNTESTED!)
    solution in the attached file, or http://s.crosstwine.com/spb/05622ef3.
    Cheers, -D
    satishbabub writes:
    > Hello Lawrence ,
    > im getting .
    > ; -- Init
    jfet-fno.il
  • AdiBharati
    AdiBharati over 13 years ago
     Thank you so much..
    That did help a lot.
  • newbee
    newbee over 12 years ago
    I   try  this, but get  the  following  error  message.
    load("/users/bg027204/CADENCE_SKILL/CCSencapRodPcell.il")
    function CCScreateBoxAndLabels redefined
    *WARNING* Invalid libId - nil
    *WARNING* (DB-270205): dbOpenCellViewByType: must specify either a libName or a contextId.
    t
