  3. pCell skill for beginners
  • Replies 21
  • Subscribers 154
  • Views 42122
stuso
stuso over 17 years ago
i'd like some advice for creating my first simple pCell from skill. I have no skill experience so i'm looking for a good place to start.
My ultimate aim (for now) is to create a rectangular via array with X and Y stretch handles. For example you have M1->M4(the top & bottom layers would be parameters) that you can stretch in X or Y and it fills with the max vias allowed by spacing rules. However to begin with i'd be happy to create a parameterised rectangle of M1 that i can stretch in one direction & take it from there.
Pointers to on-line tutorials and very simple examples would be great, right now i am blindly searching around source-link.
Stu
  • skillUser
    skillUser over 17 years ago
     Hi Stu,
    Here is a simple example on SourceLink that has a stretch handle, I'm also posting the code here, but I recommend viewing the full solution for a little more detail and description.  If I get time later I can look at creating a better example.  Look at the  rodFillBBoxWithRects() function or the subRectArray argument to the rodCreateRect() function.
    Lawrence.
    /* CCSencapRodPcell.il
    Group           Custom IC, Cadence Design Systems
    Language        SKILL
    Revision No.    1.1
    Date Created    Aug 06, 2008
    Last Modified
    Tested in       IC5141
    Lint score      94 (best is 100)
    Description:
    A simple example of an encapsulated PCell with a stretch handle and
    CDF for one of the parameters.  CDF is created for the two parameters
    and the stretchable parameter is either hidden, or visible but not
    editable on the Edit Instance Properties form.
    NOTE: The Lint score is not 100 because SKILL Lint does not recognise
    pcCellView as a legal parameter, but instead thinks it is a global.
    SCCS Info: @(#) CCSencapRodPcell.il 08/11/08.11:19:22 1.1
    * DISCLAIMER: The following code is provided for Cadence customers *
    * to use at their own risk. The code may require modification to *
    * satisfy the requirements of any user. The code and any *
    * modifications to the code may not be compatible with current or *
    * future versions of Cadence products. *
    * THE CODE IS PROVIDED "AS IS" AND WITH NO WARRANTIES, INCLUDING *
    * WITHOUT LIMITATION ANY EXPRESS WARRANTIES OR IMPLIED WARRANTIES *
    * OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. *
    ;; This is the function that does all the work in creating the
    ;; PCell shapes, labels etc. This routine can be tested outside
    ;; of the pcDefinePCell statement, and it goes through SKILL Lint
    ;; with better results too.
    procedure(CCScreateBoxAndLabels(cv w l "dnn")
    let( (rectRodObj)
    ;; create a rectangle on metal1 with x & y dimensions set by w & l
    rectRodObj = rodCreateRect(
    ?name "myRect"
    ?cvId cv
    ?layer list("metal1" "drawing")
    ?width w
    ?length l
    ?origin list(0 0)
    ;; create labels to show the w and l parameters
    dbCreateLabel(cv list("text" "drawing") list(0 0)
    sprintf(nil "%2.8f" w) "lowerLeft" "R0" "stick" 0.05)
    dbCreateLabel(cv list("text" "drawing") list(0 0.2)
    sprintf(nil "%2.8f" l) "lowerLeft" "R0" "stick" 0.05)
    ;; create a stretch handle for the width, in the X dimension, it
    ;; will display as "width = <value>" and change by 0.1 increments
    rodAssignHandleToParameter(
    ?parameter "w"
    ?rodObj rectRodObj
    ?handleName "centerRight"
    ?stretchDir "X"
    ?displayName "width"
    ?displayExpression "w"
    ?updateIncrement 0.1
    ); rodAssignHandleToParameter
    ); let
    ); procedure CCScreateBoxAndLabels
    ;; Create the PCell, the "drawing routine" is encapsulated in the
    ;; CCScreateBoxAndLabels function which does all the work
    pcDefinePCell(
    list(ddGetObj("test") "encapRodPcell" "layout")
    (w 1.0)
    (l 0.6)
    let( ((cv pcCellView))
    CCScreateBoxAndLabels(cv w l)
    ); let
    ;; Create the CDF for the 'l' and 'w' parameters, the width (w)
    ;; parameter is either hidden or displayed but not editable.
    let( (cellId cdfId)
    when(cellId = ddGetObj("test" "encapRodPcell")
    ;; if the cell CDF already exists, delete it
    when( cdfId = cdfGetBaseCellCDF(cellId)
    cdfDeleteCDF(cdfId)
    ;; create the base cell CDF
    cdfId = cdfCreateBaseCellCDF(cellId)
    ;; create the parameters
    cdfCreateParam( cdfId
    ?name "l"
    ?prompt "Length"
    ?defValue 0.6
    ?type "float"
    ?display "t"
    ?name "w"
    ?prompt "Width"
    ?defValue 1.0
    ?type "float"
    ;; comment out the next line and uncomment the lines below
    ;; it if the parameter is to be visible but not editable
    ?display "nil"
    ; ?display "t"
    ; ?editable "nil"
    cdfSaveCDF(cdfId)
    ); when
    ); let for CDF creation
  • stuso
    Hi Lawrence,
    thanks as usual for your input.  I just tried to load this skill into my icfb but it returned:
     *WARNING* Invalid libId - nil
     *Error* eval: unbound variable - cv
    I guess cv is cell view and maybe i need to pass some sort of variable or define cv before i load the skill.
    I've printed the skill off to have a look at it over the weekend incase i'm missing something obvious.
    Stu
  • skillUser
     Hi Stu,
    You will need to create a library named "test" so that when the code is loaded the libraryId is found and then used to create the "encapRodPcell" cellview in that library.  The library should have technology information in it, for example, the "metal1" "drawing" layer is used in this example. There is a sample techfile in <cds_install_dir>/tools/dfII/samples/techfile/mpu.tf which contains this layer if you don't have a ready example to play with.
    Hopefully this will help you get started.
    Cheers,
    Lawrence.
  • skillUser
    Hi Stu,
    How are you getting on with your PCell development?  Hope it is going well, let us (the community) know if we can help.
    Lawrence.
  • stuso
    Hi Lawrence, thanks for asking.
    i had a quick try & the cell had no stretch handles for me.
    I need to spend a bit of time looking into this, its a side project for me just now but i'll definately be back to bug you over the next few weeks when i get round to it.
    Stu
  • skillUser
    Hi Stu,
    I forgot to mention that the stretch handle visibility can be controlled by the user from the Options->Display "Stretch Handles" toggle, which may be off by default.
    Lawrence.
  • stuso
     Yes, that works now, thanks
  • stuso
    Hi Lawrence, i've been using your example (thanks for that) and i've had managed to make some good progress (for a beginner). I now can generate a pCell with say M1,VIA1,M2,VIA2 & M3 which has X&Y stretch handles.  I've used M1 as my main ROD rectangle with the other 4 layers as subrectangles.
    It works nicely in the sense that I can place & stretch it around, it looks like all the layers are in place and the correct size. I have a couple of immediate issues & a more generic question.
    1) How do i set a miimum value for parameters, currently i can stretch the pCell to 0um then i can't recover it, i have to select it (by area for example) then delete it.
    2) It fails to run PVS DRC with message:
      *WARNING* Pcell evaluation for stu_test_skill/GGL_pCell_M1viaM3/layout has the following error(s):
    *WARNING* ("eval" 0 t nil ("*Error* eval: undefined function" GGLcreateViaM1M3))
    *WARNING* Error kept in "errorDesc" property of the label "pcellEvalFailed" on layer/purpose "marker/error" in the submaster.
    FATAL (449): Pcell evaluation failed. This could happen as a result of either a syntax error or the use of an unsupported PIPO function in Pcell SKILL code. Only db*() and rod*() functions can be used in Pcell SKILL code. To continue, either use the 'Ignore Pcell evaluation failure' option in Stream  In/Out Options or fix the Pcell SKILL code.
    pvsvirt: PROBLEM happened while processing strmout.
    3) This is the more generic Question. Once i have a nice clean pcell code how should i store & implement the Skill for the design team. For example i could just load the code from the project .cdsinit, would that be wise? I noticed that when i start a new session i have to reload the skill function else i get the pCell evaluation failed message in the layout view.
    Thanks for you help
    Stu
    Here is my code, all feedback is very welcome:
    procedure(GGLcreateViaM1M3(cv w l "dnn")
      let( (rectRodObj)
          ?name    "gglVIA1m1m3"
          ?cvId    cv
          ?layer    list("M1" "drawing")
          ?width    w
          ?length    l
          ?origin    list(0 0)
          ?subRectArray     list(
            list(
                ?layer     list("M2" "drawing")
                ?width     w
                ?length     l
            list(
                ?layer     list("M3" "drawing")
                ?width     w
                ?length     l
            list(
                ?layer     list("VIA1" "drawing")
                ?width     0.07
                ?length     0.07
                ?lowerLeftOffsetX    0.05
                           ?lowerLeftOffsetY    0.05
                           ?upperRightOffsetX   -0.05
                          ?upperRightOffsetY   -0.05
                           ?spaceX              0.075
                           ?spaceY              0.075
            list(
                ?layer     list("VIA2" "drawing")
                ?width     0.07
                ?length     0.07
                           ?spaceX              0.075
                           ?spaceY              0.075
    ;; create a stretch handle for the width & length
        ?parameter        "w"
        ?rodObj        rectRodObj
        ?stretchDir        "X"
        ?updateIncrement    0.005
        ?parameter        "l"
        ?rodObj        rectRodObj
        ?handleName        "upperCenter"
        ?stretchDir        "Y"
      ); let
    ); procedure
    ;; GGLcreateViaM1M3 function which does all the work
    pcDefinePCell(
      list(ddGetObj("stu_test_skill") "GGL_pCell_M1viaM3" "layout")
        (w 0.33)
        (l 0.33)
        GGLcreateViaM1M3(cv w l)
      ); let
    let( (cellId cdfId)
      when(cellId = ddGetObj("stu_test_skill" "GGL_pCell_M1viaM3")
          cdfDeleteCDF(cdfId)
          ?name    "l"
          ?prompt    "Length"
          ?defValue    0.33
          ?type    "float"
          ?display    "t"
          ?name    "w"
          ?prompt    "Width"
          ?defValue    0.33
          ?type    "float"
          ?display    "t"
        cdfSaveCDF(cdfId)
      ); when
    Andrew Beckett over 17 years ago
    Hi Stuart,
    1. Simple way would be to add something like w=max(w 0.2) and l=max(l 0.2) (0.2 is just an example of a minimum) before the rodCreateRect. That would clip it to the minimum value.
    2. Surround the pcDefinePCell call in a procedure definition, and then load the SKILL code from a file called libInit.il in  the library that contains the pcell ("stu_test_skill" in this case).
      The reason for wrapping the pcDefinePCell is a procedure is that you don't want to redefine the pcell every time it gets loaded - just when you choose. By having the code loaded from libInit.il, it will get auto-loaded by PVS, by Virtuoso, for any user that references the library. If you put the code in the .cdsinit, it won't get picked up by PVS.
  • skillUser
    Hi Stu,
    In addition to what Andrew has said, you can also use a CDF callback for a parameter as a validation check, this is a good use of a CDF callback - please also bear in mind the advice in the following solution (written by Andrew):  The Dangers of CDF Callbacks
    If you use CDF for a parameter, you can use this to set the Display of the parameter which can appear differently to the parameter name, and you can use the CDF to control whether a parameter is displayed or not. You can create the CDF through SKILL also, so this can be in the file that is loaded by the libInit.il (or in that file directly) alongside the PCell code itself.  Depending on the amount and complexity of your code, you may wish to have multiple files to house the SKILL in, e.g. you've got multiple PCells and want one SKILL code file per cell. You might then just load all of the SKILL from the libInit.il, as in this example:
    let( ((libName "pcells") path skillPath ilFiles)
    ;; you might have the code in a subdirectory, if so, add this to the path path = ddGetObjReadPath(ddGetObj(libName))
    skillPath = getSkillPath()
    unless(member(path skillPath)
    setSkillPath(cons(path skillPath))
    ilFiles = setof(files getDirFiles(path) rexMatchp("\\.il$" files))
    foreach(file ilFiles
    unless(file == "libInit.il"
    printf("Library %s libInit.il loading %s\n" libName file)
    loadi(file)
    ); unless the file is this file
    ); foreach
    t
    ); let
    An easy way to write the SKILL to create the CDF is to create the CDF using the form-driven interface and then use cdfDump() to write this to a file as SKILL code.
    Good luck!
    Lawrence.
