  3. how to export gds file using skill
  • Views 16325
VEERA PRAMOD
VEERA PRAMOD over 17 years ago
Hi all..
   i had written a skill program to export gds of a edit cellview directly it is not working properly.Some times it is working,some times it taking icfb into infinite loop.Please tell me the prcocess to export gds file for a edit cell view with out giving any input if you know.
Thank you.
Veera Pramodu Kotrika
    Andrew Beckett over 17 years ago
    Something like this should do it:
        defun(CCSrunStrmout (lib cell view)
    	let((streamOutKeys templateFile prt id)
    	    streamOutKeys=ncons(nil)
    	    streamOutKeys->libName=lib
    	    streamOutKeys->primaryCell=cell
    	    streamOutKeys->viewName=view
    	    streamOutKeys->outFile="PIPO.log"
    	    streamOutKeys->errFile="PIPO.err"
    	    templateFile=makeTempFileName("./streamOutKeys")
    	    prt=outfile(templateFile)
    	    fprintf(prt "streamOutKeys='")
    	    pprint(streamOutKeys prt)
    	    newline(prt)
    	    close(prt)
    	    id=ipcBeginProcess(
    		sprintf(nil "pipo strmout %s" templateFile)
    		CCSstrmDataHandler
    		CCSstrmDataHandler
    		CCSstrmExitHandler
    	    ) ; ipcBeginProcess
                ; use ipcWait(id) if you want to wait for it to finish
    	) ; let
        ) ; defun
        defun(CCSstrmDataHandler (_id data)
            printf("%s" data)
        defun(CCSstrmExitHandler (_id status)
            printf("Stream Out exited with status %L\n" status)
    Note that I've not tested the above, it was modified from some similar code I already had, in order to protect the innocent...
