  3. enterpath function
  • Views 15335
enterpath function
Vignesh054
Vignesh054 over 17 years ago
I was tring to use enterpath function, I want to know about about the prompts, doneProc options in enterpath.
And if possible please tell me more about all the options.
 enterPath(
[?prompts l_promptList]
[?points l_pointList]
[?wantPoints x_pointLimit]
[?form s_form]
[?addPointProc t_addProcName]
[?delPointProc t_delProcName]
[?initProc t_initProcName]
[?doneProc t_doneProcName]
[?formProc t_formProcName]
[?pathStyle t_pathStyle]
[?pathWidth f_pathWidth]
[?beginExtent f_beginExtent]
[?endExtent f_endExtent]
[?dontDraw g_dontDraw]
[?alwaysMap g_alwaysMap]
[?acceptString g_acceptString]
[?acceptNumber g_acceptNumber]
[?noInfix g_noInfix]
[?cmdName t_cmdName]
Vignesh T K
    Andrew Beckett over 17 years ago
    Did you actually look at the documentation?
    Often this kind of question comes because somebody has used cdsFinder to find the function template, but that is merely a quick reference and not a substitute for the full documentation.
    Search for enterPath in cdsdoc or cdnshelp (depending on which version you're using of the IC tools) or look in <ICinstDir>/doc/skuiref/skuiref.pdf (I think that's what it's called; I'm doing this from memory).
