  3. change selected layer
  • Replies 13
  • Subscribers 152
  • Views 22709
vincentmt
vincentmt over 17 years ago
if i wish to change a selected layer from one data type to another data type, what i should type in CIW ? (without using leHiEditProp())
etc i want to change M1 "drawing" to M1 "B5" on a selected rect/ poligon.
  • vincentmt
    vincentmt over 16 years ago
    Hi how,
    i'm try to setting some bindkey in the the key pad(num lock) it's doesn't work.
    " bindkey ("Layout" "Meta<Key>KP_Ins"    "ChangeLayerAttr(?layer \"M10\")")
    it will promt me
    "*WARNING* Modifier Alt is unassigned, illegal or disabled.
    *WARNING* Unrecognized key encryption: Alt<Key>KP_0.
    *WARNING* Unrecognized key encryption: Alt<Key>KP_0."
    i'm can't find why.
    if me setting " bindkey ("Layout" "Ctrl<Key>KP_Ins"    "ChangeLayerAttr(?layer \"M10\")")"
    error message is
    *WARNING* (LE-104018): Setting the entry layer to be invisible
    but if i'm setting other then "Ins--"0" it's work for "Ctrl" but not for "Meta (Alt)" is it we can't setting the "Meta" bindkey for key pad keys?
    and how i'm going to set bindkey on the "Ins--0" key??
    please advice. Thanks in advace
    KK.
  • kbhow
    kbhow over 16 years ago
    Hi KK,
    I not sure why but as i know, you can't set binkeys for "Alt" key. You find enrecognized key encription for "Alt" key. Try to use "Shift" of "Ctrl", it should works.
    Since you didn't attach any coding for function ChangeLayerAttr, i assume this function is changing the layer attribute to invisible. Before changing the layer attribute to invisible, please make sure that the layer that you going to change is not entry layer. You can't change entry layer to be invisible.
    How
  • TrevorB
    TrevorB over 16 years ago
     IC6 does not permit assigning bindkeys with the Alt modifier - by default.  You can change that with this .cdsenv setting:
    ui                      enableMenuShortcuts             boolean         nil
