  3. change selected layer
  • Replies 13
  • Subscribers 152
  • Views 22701
vincentmt
vincentmt over 17 years ago
if i wish to change a selected layer from one data type to another data type, what i should type in CIW ? (without using leHiEditProp())
etc i want to change M1 "drawing" to M1 "B5" on a selected rect/ poligon.
    Andrew Beckett over 17 years ago
    Assuming all the selected shapes are on the same layer (or you don't mind
    changing other things too - in other words, with no sanity checking), it's just:
    geGetSelSet()~>purpose="B5"
  • kbhow
    kbhow over 17 years ago
    Hi vincent,
     You can direct change the layer attributes of selected object.
    obj_id = car(geGetSelSet())
    obj_id~>purpose = "B5"
  • vincentmt
    Thanks andrew and kbhow.
    so how about if i want to change the layer and the purpose at the same time? is it posible to do it? i have try out, i can't make it if want to do this two action at the same time.
  • kbhow
    Hi Vincent,
     To change the layer and layer purpose at the same time, u can do this.
    obj_id~>lpps = list("M2" "net")
    How
  • vincentmt
    hi kbhow,
    i try your advice, but it's didn't show any changes.
  • kbhow
    Hi Vincent,
    It is my typo... the layer and purpose can be change easily by changing the object's lpp
    FYI, you can view all the info of the object by using the tail operator.
    obj_id~>??
    And to change the layer and purpose,
    obj_id~>lpp = list("M2" "drawing")
    will helps
    How
  • kbhow
    Hi Vincent,
    Your coding should not working cause it is not proper constructed. You may try this.
    procedure( changePurpose( @optional (purpose "drawing"))
        let((selset)
            selset = geGetSelSet()
            foreach( sel selset
                    sel~>lpps = list(sel~>layerName purpose)
            );foreach
        );let
    );proc
    ;; Set bindkeys
    hiSetBindKey( "Layout" "<Key>F1" "changePurpose()")      ;by default, it will change to drawing
    hiSetBindkKey("Layout" Shift<Key>F1" "changePurpose("pin")")
    You don't really need to do the foreach. You can just do:
      geGetSelSet()~>lpp='("newLayer" "newPurpose")
    or:
      geGetSelSet()~>purpose="newPurpose"
    if you just want to change the purpose.
    How's code won't work because it uses sel~>lpps inside the foreach, and it should be sel~>lpp (the attribute is called lpp, not lpps)
  • kbhow
    Thanks Adrew for the good catch. =D
  • vincentmt
    thanks andrew and how for the help. :)
