  3. How to derive a layer using SKILL ?
  • Views 15492
marbs
marbs over 17 years ago
 How can I derive a layer by using SKILL ? to be used
in DRD. Any examples are appreciated .
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
     Which release?
     The derived layers defined in the techFile in IC6.1 are used automatically by DRD. If you want to derive a drawn layer, you have to use the layer booleans. Look in cdsFinder for dbLayer and this will list the layer booleans available. You can then find examples in the help manuals.
    Ted
  • marbs
    Good evening sir,
    I am using VXL version v5.10.41.500.5.109.
    Thank you for the response. Assuming I want to derive the F layer of a vertical transistor (VPNP), How should I do it in SKILL?
