  3. A question about cdfUpdateInstParam() ?
  • Subscribers 152
  • Views 16232
IC Layout
IC Layout over 17 years ago
 Hi! all,
           I am trying to instantiate transistors from schematic to layout. Initially I wrote this code(not hierarchical code).
  procedure(new_gen()
cv = geGetEditCellView() ;where cv is the 'schematic cell view
let( ( i )
i = 0
foreach(inst cv~>instances
  if(inst~>libName == "gpdk090" then
      case(inst~>cellName
      (("pmos1v" "nmos1v" "pmos2v" "nmos2v")
          mos = dbOpenCellViewByType(inst~>libName inst~>cellName "layout")
          if(inst~>m == "1" then
          lay = dbCreateInst(target mos inst~>name i:0 "R0") ;where target is the layout window
          dbCopyProp(inst lay)
          cdfUpdateInstParam(lay)
          ;println(inst~>m)
          else
          if(inst~>m != "1" then
          for(r 1 atoi(inst~>m)
          name = strcat(inst~>name "." artMakeString(r))
          lay = dbCreateInst(target mos name i:0 "R0")
          lay~>m = 1
          ;println("lap2")
          i = caadr(lay~>bBox) + 3
      (t
          println(inst~>cellName)
      );case
  );foreach
);let
);proc
new_gen()
Now the problem is I am getting the transistors (pmos&nmos) which are having  same properties.(Also thse properties reffered to the transistor which is encountering at first time in 'cv~>instances list' )
Can someone correct this code for me, please.....
Thanks in advance...
Prabhakar. K -- Layout Engineer
  • mims
    mims over 17 years ago
    I am not sure that I understood your question, but my experience with cdfUpdateInstParam is that it the instance cdf parameters will change after using it. It will refresh the layout, but the values will be set to the previously used I think...  If you want to have specific values for some parameters you need to set them yourself after the cdfUpdateInstParam has been called.
  • IC Layout
     Hello! Mr. Mims, Thanks for your kind response....
    First of all I would like to say sorry....Because I got the solution after submitting the query.
    I am really very sorry.. If I have wasted your time...
    Instead of these two lines I have used this ...
               cdfSyncInstParamValue(inst lay)
    And this is what I am looking for.....
    Sorry.. Once again...
    Thanks & Regards
    Prabhakar. K  -- Layout Enginner
  • mims
     Please, no problem
    And I will try the  cdfSyncInstParamValue function if I need to copy instances...
     mims
  • IC Layout
     Please, let me know your problem some more clearly...
    Do you want to copy an instance which is already created in the layout ...?
    Or What else....
    Regards..
