  3. Abutment of one object with itself. How?
  • Subscribers 150
  • Views 7747
Zelli
Zelli over 17 years ago
I do not have left and right objects. (leftdiff, rightdiff). I have one diffusion object. Thus, I cannot use this standart:
"procedure(tranAbutFunction(instA instB pinA pinB pinAside conn event @optional group)
let(( result pinAcontP pinAstrP pinBcontP pinBstrP pinAw pinBw pinAcontV
pinAstrV pinBcontV pinBstrV drop_moving debugging eqW )"
And how I may use abutment in my case ?
    Andrew Beckett over 17 years ago
    I'm  not entirely sure what you mean, because it would be meaningless to abut one object with itself.
    I'm guessing that what you're saying is that you have a single piece of diffusion under the transistor, and so when you abut one transistor to another, you don't know how to handle that?
    Well, the key thing is that the abutting objects are pins. When the abutment of two pins is detected, it can then figure out the connectivity information, and know whether there are other connections, and consequently your abut function can choose to do the abutment, either leaving the metal connection present or not. Normally the abutment is triggered by diffusion source and drain pins, because you need to have pins which will be there after the abutment has occurred; if you've removed the metal pins from either or both abutting transistors as a result of your abut function, there's nothing left to manage the abutment...
    So usually you would create a diffusion pin on the source region and drain region - you can keep the single piece of diffusion underneath the transistor - I'm assuming that doesn't have any pin on it right now, because otherwise your transistor would be shorted...
    The other main important feature of abutment is that the abutting pins must have the same pin name before and after abutment. Often pin names are not that important in Virtuoso; it's usually the terminal name which matters. However in this case, the pin name (which is somewhat arbitrary) is how the abutment system knows which pin is which before and after the abut function is called - this is necessary because the pcell code will have rebuilt the pcell submaster, and so it needs some way of identifying which pin was which (the db object ids will have changed).
  • Zelli
    Thanks, but... I will explain:
    Аssume there is such transistor (I will try to represent top view):
    bgss
    bgds
    bgss
    b - substrate
    g - gate
    s - source
    d - drain
    I want that abutment worked like this:
    bgss     ssgb     bgsssgb
    bgds +  sdgb =  bgdsdgb
    bgss     ssgb     bgsssgb
    And I write:
      when(diff~>dbId != nil objId = diff~>dbId
               when(objId~>pin != nil objId~>pin~>name = "source")
               dbReplaceProp(objId "vxlInstSpacingDir" "list" list("right"))
               dbReplaceProp(objId "vxlInstSpacingRule" "float" msdd)
               dbReplaceProp(objId "abutAccessDir" "list" list("right"))
               dbReplaceProp(objId "abutFunction" "string" "tranAbutFunction")
               dbReplaceProp(objId "w" "float" W)
               ;dbReplaceProp(objId "contactParam" "string" "leftcnt")
    Result:
    >>> spcMosAbutFunction
    instA~>name = "|MA1"
    instB~>name = "|MA4"
    pinA~>pin~>name = "source"
    pinB~>pin~>name = "source"
    pinAside = 8
    conn = 1
    event = 2
    group = db:239227436
    *Error* get/getq: second arg must be a symbol or a string – nil
    >>> spcMosAbutFunction
    pinA~>pin~>name = nil
    pinB~>pin~>name = nil
    pinAside = 0
    conn = 0
    event = 3
    Calculating un-abutment
    Returning result t
    But in standart example it is written:
      when(leftdiff~>dbId != nil objId = leftdiff~>dbId
               dbReplaceProp(objId "vxlInstSpacingDir" "list" list("left"))
               dbReplaceProp(objId "abutAccessDir" "list" list("left"))
               ;dbReplaceProp(objId "abutClass" "string" cellViewId~>cellName)
      when(rightdiff~>dbId != nil objId = rightdiff~>dbId
               when(objId~>pin != nil objId~>pin~>name = "drain")
               dbReplaceProp(objId "contactParam" "string" "rightcnt")
    and abutment work in this case:
    sgd     sgd    sg*gd
    sgd +  sgd = sg*gd
    and in this:
    sgd     dgs    sgdgs
    sgd +  dgs = sgdgs
    Why does not work  my variant ?
  • Zelli
    I've read through your post three times, and I cannot fathom out what you're telling me. Some of your descriptions are rather cryptic, to say the least, and just the snippets of code are not enough for me to work out what is happening, what is not happening, or even what you're expecting to happen!
    Probably the best thing would be to contact customer support with a testcase illustrating your problem. Then there's some chance of being able to work out what your problem is and how to solve it.
    Best Regards,
